MK 1 E30, still too high?
  • Ra1994gh
    • Dec 2015
    • 8
    Hi, I have a prefacelifted E30 320i, with a complete 325i rear axle.
    I chaged the the shocks in front and rear to TA-Technix sport (yellow ones), and it got new original mounts in front. It also got some lowering 40mm springs in the back, and 60mm ones in the front. But the car is still too high.
    Is there any way to get it lower especially in the back?
    I know that the prefacelifted E30 has a higher distance from under the rear fender to the center of the wheel, but should'nt it be possible to have the rear tires at least "fill out" the space over the wheel?
  • Ra1994gh
    • Dec 2015
    • 8
    • McGyver
      • 4633
      It should settle a bit after driving for a while. Also, you can remove the rear spring pads to get it about 15mm lower in the back.
      The best solution would be to get lower springs (H&R Race will be REALLY low, H&R Sport will be pretty low). Just remember that if you have shitty roads, you don't want to be too low. Also, the trailing arm suspension on e30s will give you excessive camber if you are low. So you'll wear out tires pretty quickly.
      • ak-
        • 12422
        Your rear tires are also too small giving it that illusion as well.
        1991 325iS turbo
        • McGyver
          • 4633
          I think he means you're tires are slightly stretched, so they look a little smaller. Also, the aspect ratio is very low, which gives you a shorter side wall. The stock tire size (US) is 195/65-14 and it looks like you have a 215/40-16. So your tires are 1.2 inches SHORTER in diameter than stock. Also, your sidewall is ~32% shorter than stock. Here is a calculator for you to play with:
          The best tire size calculator. Use our tire size calculator to find tire size specs and suggested tire sizes. Then check prices for all available tire sizes.
          • staysideways
            • Dec 2013
            • 373
            Originally posted by Ra1994gh
            All you need is ie3s
            1989 E30 325i Sedan Alpine
            • agent
              Vice Grand Pubaa
              • 7960
              Originally posted by staysideways
              All you need is H&R Sports
              Fixed.
              See the build thread for Klaus, linked in my signature.
              Originally posted by kronus
              • Ra1994gh
                • Dec 2015
                • 8
                I again. Thank you for your answers. I looked at your Klaus thread, where you installed the H&R Sport rear springs, but it is still kinda high. Dont you think?
                I know it will eat my tyres, but that is a choice i am willing to take.
                Next time I will get some tyres with a little bit more profile on (higer).
                If i remove the spring pads in the rear, do I really get it lowered 15 mm? Is there any bad things about it?
                • gman325is
                  • 61
                  The e30's built before 7/87 have higher rear wheel arches, so it looks like they are sitting higher.
                  I have had my spring pads out on my Spec e30 for years, does not seem to be a problem.
                  Greg
                  1987 SE30 Race Car
                  1989 325is DD
                  1990 325is(TrackRod)
                  1969 Alfa Romeo GTV 1750
                  • Todd Black 88
                    • Oct 2007
                    • 3449
                    The tires are a big visual issue. That is the size tire you would run on a 17" wheel, to keep the rolling diameter as close as possible to stock.
                    For 16" the proper tire is 225/45
                    Originally posted by codyep3
                    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                    2001 silver/Blk 325 cabby. SOLD
                    2002 325xit Sil/blk. SOLD
                    2010 F650gs twin
                    • agent
                      Vice Grand Pubaa
                      • 7960
                      Nope. For that car and my intent to make it OEM+ it's perfect.
                      My other E30 is lower, but it was built for a different purpose.
                      • Ra1994gh
                        • Dec 2015
                        • 8
                        Thank you all.
                        So I want to buy these H&R race springs. But I live in Denmark and I did not find any i Europe who sell these.
                        Are they called something else over here?
                        • Ra1994gh
                          • Dec 2015
                          • 8
                          Any one?
                          • reelizmpro
                            • 9542
                            H&R Race are E30 M3 fitment.
                            88 M3 - LACHSSILBER
                            89 M3 - ALPINEWEISS II
                            • staysideways
                              • Dec 2013
                              • 373
                              I know the the back ones will fit but idk about the front ones
