lower strut bolt
  • sam_
    • May 2014
    • 630
    lower strut bolt
    heyo,
    it would appear part #2 & #3 in this photo has somehow fallen off my car and I need to replace them asap.
    however, everywhere I have checked lists the part as NLA. would you guys happen to know where I can pick one up?
    thanks!
    sam
    1991 325i
    flickr
    @sambhaskins
  • Cabriolet
    • 9620
    you mean 2 and 3.
    go to your local hardware store and get a "M12X1.5X65" bolt it's not hard to come by.
    nominal diameter is 12mm, 1.5 threads per mm and 65mm long.
    Much wow
    I hate 4 doors
    • sam_
      • May 2014
      • 630
      you mean 2 and 3.
      yep, thanks for the correction and for the help!
      1991 325i
      flickr
      @sambhaskins
        • 37833
        If you bring your car for the timing belt I can throw one on for you!
        Grover Beach, California
        BimmerHeads.com
        • sam_
          • May 2014
          • 630
          so whenever the hex bolt came out it pulled this guy with it
          tried greasing it up and hitting it w a mallet but it wants to stay put - any tips on getting it back in there?
          1991 325i
          flickr
          @sambhaskins
          • gte175x
            • 150
            I would be weary of hardware store bolts....unless you choose the grade of the bolt correctly, you could be putting in a substantially weaker bolt.
            • sam_
              • May 2014
              • 630
              it's the same grade
              just trying to get this sleeve back in /:
              1991 325i
              flickr
              @sambhaskins
              • roguetoaster
                Biggus Tippus
                • 7830
                Use a C clamp or take the shock off and put it in a vise to reinstall the sleeve.
                I also hope you're not installing some Chineseium bolt, although this isn't the most critical of bolt points on the car by far.
                • sam_
                  • May 2014
                  • 630
                  lmaooo chineseium - that's a good one
                  i'll give those a shot thanks !
                  1991 325i
                  flickr
                  @sambhaskins
                  • TobyB
                    • 5297
                    You can also just get a longer bolt and a big washer, put the washer on the inside and draw
                    the sleeve back into the shock eye with the bolt. You might have to stop and add a stack
                    of 'spacer' washers once or twice so the longer bolt doesn't bottom out.
                    t
                    • sam_
                      • May 2014
                      • 630
                      slowly finessing
                      1991 325i
                      flickr
                      @sambhaskins
                      • sam_
                        • May 2014
                        • 630
                        got it done - thanks pimps
                        Sam
                        1991 325i
                        flickr
                        @sambhaskins
                        • noid
                          • 1537
                          Best place to go to get NLA bolts is a place like fastenal, they will always likely have it in stock, of high quality and only marginally more expensive (when we are talking about bolts that means only more expensive by a few cents).
                          I know for a fact the local BMW dealership here goes to fastenal for their NLA or quick turn around bolts. I have seen the techs in there on multiple occasions.
                          Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
                          Your resource to tools and tips: www.rtstools.com
                          • roguetoaster
                            Biggus Tippus
                            • 7830
                            Sam
                            Cool, ho? Or are we all collectively pimps? It's unclear.
                            • Kershaw
                              • 11822
                              Don't you need a business account for fastenal?
                              AWD > RWD
