Steering swivel joint (airbag), where to find?!
  • RandyMac
    • May 2018
    • 11
    32311156348
    Rack replaced, tie rods replaced, but steering doesn't feel smooth. I suspect the joints and rubber are worn out. Doesn't look like anyone has the part! Any suggestions? Surely someone must have figured out how to upgrade, replace, and repair it?
    - A
  • mtech325
    • May 2008
    • 572
    Bump for a good question. I would like to change mine as well on my airbag car.
    • RandyMac
      • May 2018
      • 11
      Shocked - nobody has ever replaced that joint? Serviced it? Swapped it with something else?!
      • Ali
        • Mar 2019
        • 53
        I would just get 32311153993 and go drill out bolt/nut route until able to find actual part, if u joint is still in good condition. W/ red thread locker or double nut for each bolt just to be safe.
        • PDXPeter
          • Apr 2018
          • 225
          I drilled out the studs on the guibo and just replaced that part. Its kind of a pain since they are really pressed in there and super solid. Took about an hour. IIRC the guibo was like $10.
          • AndrewBird
            The Mad Scientist
            • 11898
            There are aftermarket ones available that eliminate the rubber bushing.
            • PDXPeter
              • Apr 2018
              • 225
              You can also pull the rubber out and just bolt them together.
              • RandyMac
                • May 2018
                • 11
                Bump because I've had others ask me the same question... what have people actually *done* to replace the part? I'm less worried about the rubber, more so about the joints themselves. I replaced my e46 joint not long ago, the old joint did not move freely at all.
                • nrubenstein
                  • 3148
                  Unfortunately, it appears that the answer today is “fabricate your own.”
                  2002 BMW M3 Alpinweiß/Black
                  1999 323i GTS2 Alpinweiß
                  1995 M3 Dakargelb/Black
                  - S50B32/S6S420G/3.91
                  1990 325is Brilliantrot/Tan
                  1989 M3 Alpinweiß/Black
                  • CabbE30
                    • Aug 2009
                    • 2358
                    I run the garagistic delrin flex coupler. I recommend it. https://store.garagistic.com/E30-BMW...SABEgIoUvD_BwE
                    Significantly improved driver feedback.
                    If the joints are bad then you need new joints! Not rocket science.
                    • varg
                      Florida Turbo Man
                      • May 2014
                      • 3440
                      Reading isn't rocket science, either:
                      OP, pelican's site says they have it: https://www.pelicanparts.com/More_Info2/32311156348.htm
                      Do they actually have it? Dunno, but the website says they do. You could probably rebuild it or at least repack it if you have the tools and patience, but it would be a non-trivial task. Unfortunately BMW doesn't seem to believe in serviceable or even re-greasable u-joints.
                      IG @turbovarg
                      '91 318is, M20 turbo
                      • charlie460
                        • Sep 2019
                        • 1
                        Just acquired a 1990 325i and looking for this part as well.
                        I came across this but it explicitly specifies it only works with the non-airbag column. Is there no real way to get something like this to work with the airbag column?
                        https://www.condorspeedshop.com/prod...=7074383495214
                        Btw - I checked with pelicanparts and they do not actually have that part available unfortunately :(
                        • varg
                          Florida Turbo Man
                          • May 2014
                          • 3440
                          I do not know if the airbag car's column is significantly different from the non-airbag car where it attaches to the first joint, but given the fact that neither Vorschlag or Condor mention cross-compatibility with their versions of the product I'd say it might be.
                          Airbag column:
                          Non-airbag column with that part installed and the stock joint assembly held up for comparision:
                          Here's a sikky unit that says it is specifically for airbag equipped cars, it is unsusual that it is not mentioned on sikky's own website though.
                          https://akwyr.co/products/sikky-bmw-...rsion-assembly
                          IG @turbovarg
