Do I need a new steering shaft? Z3 Rack install trouble.
  • Azscentence
    • Apr 2014
    • 55
    Alright, so I have a 1991 bmw 325i sedan with airbags. I decided my front end needs a refresh before I put in a bigger engine. I ended up getting a bigger sway bar, poly steering flex disc, z3 rack w/spacers, control arms, tie rods, and a subframe reinforcement kit. The whole shebang. Now onto the z3 rack issues I’m having. Here’s some context with as much detail as I can manage.
    I put in the entire subframe in as a single unit. It has the rack and the control arms all together. Initially I installed everything with the knuckle hammered onto the rack splines with the idea that I could line it up with the column hanging out of the firewall (that I already trimmed for clearance.) I was having too many issues getting the splines on far enough to where I couldn’t mount the subframe. So then I decided to hammer the knuckle onto the column and align it when I had the subframe bolted in place. So that’s where I’m at right now. Subframe is bolted in with the rack attached. BUT now I’m having the issue to where the knuckle won’t attach on both ends?
    I thought at first maybe I hammered the knuckle too far onto the column splines, so I tried tapping it loose until it would come into contact with the z3 rack, but it fell to the floor before it even reached the rack splines. My thinking is that maybe I hammered the knuckle onto my column too hard and messed up something with the steering shaft in the cabin?
    I’m having up/down play in my steering wheel now. No left/right play or forward/back. Just up/down. Also if I spin the wheel quickly it doesn’t look even. It looks like it kinda “wobbles” up/down or something. Like as if my steering wheel was an oval instead of a perfect circle.
    Anyway, I can supply an image of the knuckle in the bay if needed. It just isn't long enough to connect to either end now.
    So do I need a new steering column? Could I have bent it or something? Any help would be greatly appreciated. Thank you!!
  • wspellmann
    • Sep 2016
    • 110
    Did you modify your shaft knuckle?
    My current E30 M62B44 swap
    • varg
      Florida Turbo Man
      • May 2014
      • 3439
      You need to extend the steering shaft a bit. The steering shaft is collapsible within the cabin, there is a big nut on it under the dash that you have to loosen to adjust the shaft's length. The stock steering u-joint fits on the Z3 rack as the splines are the same just in a different position, though it requires some persuasion.
      IG @turbovarg
      '91 318is, M20 turbo
