Ground Contorl?
  • PiercedE30
    • Apr 2005
    • 4220
    or you can cut down the bumpstops.
    My 2.9L Build!
    • Mystikal
      Wheel Fitment Expert
      • 9602
      Originally posted by etxxz
      on the rear 1/2"-1" should do it but the front has like a 3" gap so if you want performance and eliminate 2.5" of that gap you should do some cutting. i have a friend running billies sports on GC 500/650 and a finger.5sh of gap on the front and hits the bump stops more often than not and although i think w/o the bump stops he'll be find but he'd rather not take that chance
      That's because Bilsteins don't compress very far.
      With a set of Konis (not even any special shortened ones, just the regular SA) and cut bump stops, you have plenty of travel with the tire at fender height.
      -Jay
      • moatilliatta
        • 6149
        So running the Konis up front vs bilsteins you can run the front lower as long as its not to extreme?
        @Zakspeed_US
        • GoKart
          • Jan 2008
          • 136
          How much do you need to cut out of the front strut housings, for the GC's?
          • Mystikal
            • 9602
            For sure. There is considerably more travel with Konis and short bumpstops compared to Bilsteins.
            Jay
            • moatilliatta
              • 6149
              I took factory bump stops and cut them in half. I run konis in my ix. Im switching to coilovers soon (possibly GC) prolly will run with no bump stop. ive read people do this to. Shouldn'd be a problem with different models of the koni's im guessing.
              @Zakspeed_US
              • Mystikal
                • 9602
                Haha, no, that isn't good. I ran like that for a while, blew out both front shocks fairly quickly and experienced the most incredibly painful bottoming ever. If you want to rip your front shock towers through the hood, do this.
                Jay
                • moatilliatta
                  • 6149
                  Ix struts are already shorter. Is there some webpage where look threw to see if theres one that matches the size for the ix but shorter?
                  @Zakspeed_US
