What are the best swaybars??
  • ian e30 318is
    • Mar 2007
    • 1809
    where did you purchase the H&R setup?? sounds like a good setup.
    1991 LS1 Swapped 318is
    Instagram:
    https://instagram.com/saltybeast/
    LS Build Thread:
    https://www.r3vlimited.com/board/for...s-e30-ls1-swap
    • Van Westervelt
      • 9365
      BMP, me thinks. It has been a while.
      • ian e30 318is
        • Mar 2007
        • 1809
        is anyone just running the front sway bars without the rear. i was wondering how the car handles with just the fronts. BTW bmp does have the H&R sways. thanks for the website.
        Instagram:
        LS Build Thread:
        • jms16v
          • Dec 2006
          • 314
          ST 22/19 are nice and relatively inexpensive (~300). I am very happy with the way my car handles with these plus h&r race/ bilstein sports.
          • Madhatter
            • Oct 2004
            • 966
            24mm front here, 16mm rear adjustible :)
            Just a little project im working on
            - http://www.lse30.com -
            • Bill-B
              • Apr 2007
              • 1242
              Same set up and everyone loves it
              Originally posted by NavyE30
              I saw Vlad was posting and got excited. Then I saw there weren't any boobs and was sad.
              • 1990m3
                • 1180
                I also have ST bars all around. The front is non-adjustable and the rear is set in the soft setting. My car is completely neutral on track, I love it. I don't see the reason for bigger sways, but I prefer to adjust my suspension with spring rates rather than swaybars.
                • peteM3power
                  • 450
                  I love my ST swaybars also... The car runs very flat through corners and is not too harsh for everyday driving either... they are great swaybars!
                  Pete
                  • CorvallisBMW
                    Long Schlong Longhammer
                    • 13039
                    Best place to buy ST bars?
                    • Van Westervelt
                      • 9365
                      There are a couple guys and shops local that have them usually, Joseph out at Munich Motorwerks and a couple others.
                      • g22
                        • 274
                        Any thoughts on Racing Dynamics bars? Best place to buy?
                        • madjurgen
                          • May 2005
                          • 1203
                          Do the ST bars need reinforcements welded in the rear?
                          As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
                          You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
                          • ddavidv
                            • 344
                            Any larger than stock bar, IMO, needs the reinforcement tabs.
                            This is an easy weld job, though, for any shop with a MIG and a lift. Won't take more than an hour at most. Don't fear it.
                            • jrobie79
                              • Mar 2006
                              • 2526
                              what exactly needs to be welded? i just got a welder for myself and am looking to add bigger sways, anything else on the car that could be welded for benefit, it doesnt really cost me anything
                              1991 318i ---- 308K - retired
                              • schmidty
                                • 1253
                                You can get the rear camber kit from IE (assuming you have lowered suspension)... those need welding :D
