What are the best swaybars??
  • Massive Lee
    • Sep 2006
    • 6785
    #31
    Originally posted by jrobie79
    what exactly needs to be welded? i just got a welder for myself and am looking to add bigger sways, anything else on the car that could be welded for benefit, it doesnt really cost me anything
    First things to go would be the tabs on the trailing arms. They usually shear in compression. That's the minimum reinforcement to do. You double or tripple the thickness. Then you may need to reinforce the mounting points under the trunk, where the bushings shells are bolted. Ireland's kit is great, or you can simply add another layer from the back. No need to drill inside the trunk.
    Lee
    massivebrakes.com
