What are the best swaybars??
  • ian e30 318is
    • Mar 2007
    • 1809
    Ive been trying to decide between eibach, racing dynamics, and suspension techniques. What are the differences and also the strong points of each. thanks.
    Ian
    1991 LS1 Swapped 318is
    Instagram:
    https://instagram.com/saltybeast/
    LS Build Thread:
    https://www.r3vlimited.com/board/for...s-e30-ls1-swap
  • xLibelle
    • Aug 2004
    • 2673
    i know nothing of those mentioned. I bought IE's 25mm front bar set, but had him ship me the smaller, 19mm, rear bar for a more balanced setup. the 22 is too big
    • atomic
      • Jun 2007
      • 5691
      I have heard good stuff about Ireland Engineering sway bars and from what i have gathered they have the some of the largest available 25mm(hollow) front 22mm(adjustable) rear. I personally do not have them but have heard good things about them.
      • e30polak
        • 6136
        suspension techniques are pretty popular as well
        INSTAGRAM: @UNDR8D_EMPIRE
        • ddavidv
          • 344
          ST rear bar is a difficult install. It is made just a shade too narrow at the bends and really takes some muscle to get it in the mounts.
          IE bars are very nice. Buy them from Flying Brick and they will be less expensive and you won't have to deal with IE's marginal customer service.
          • sticksdaman
            • Apr 2005
            • 2987
            what are stock 325is sway bars
            how thick are they?
            Originally posted by ebelements
            Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
            • browntown
              • Jun 2004
              • 3524
              cheaper is a cabrio front, m3 rear with adjustable links.
              • Tarn
                • Sep 2006
                • 212
                how is Eibach
                • ian e30 318is
                  • Mar 2007
                  • 1809
                  how hard are the IE's to install?
                  Instagram:
                  LS Build Thread:
                    The fronts are easy, just bolt them in.
                    The rears are a bit more work. The first challenge is working the bar in and that's easier if you remove the shock and spring on one side. The next challenge is in locating the holes through the trunk floor for the reinforced bushing mounts. I made a needle punch by grinding down a spare bolt and used that from underneath to punch a pilot hole and then drilled from the top.
                    It is essential that you weld in reinforcements for the tabs on the trailing arms. A triangulated reinforcement is just about required (like what Turner sells) to keep from bending the tabs.
                    • ddavidv
                      • 344
                      What he said. Time consuming, but not hard. The IE stuff fits really well. The tabs for the lower control arm need to be welded on but it's a simple weld anyone can do.
                      • So Live
                        • 2512
                        How big is the e30 m3 rear bar?
                        -Chris
                        • var1ant
                          • Apr 2005
                          • 509
                          rear m3 bar is 14 mm
                          stock 325is is 13.5mm
                          stock 325i is 12mm
                          I'm not really sure about the accuracy of these though.
                          '87 alpine white 325is
                          • ian e30 318is
                            • Mar 2007
                            • 1809
                            Originally posted by Tarn
                            how is Eibach
                            +1.
                            Instagram:
                            LS Build Thread:
                            • Van Westervelt
                              • 9365
                              I have H&R's. Love them. :) 22 in front, and 19 out back. Both adjustable.
