sways or strut braces
  • themitchster359
    • 654
    i just lowered my car and want to get some more suspension/chassis stiffness. do you recommend sways or strut braces first for autocrossing??
    89 Alpine White e30 325i
  • Mike B.
    • Jan 2006
    • 987
    Here is what I would recommend:
    1) Custom valved shocks for your spring rate
    2) Adjustable sway bars
    IMO strut braces are over-rated. If you want chassis stiffness, weld in a rollbar.
      • 34844
      they serve entirely different purposes - but swaybars are going to make a bigger difference than strut braces.
      yeah, cause weld in rollbars are great for street cars :roll:
      • submwar
        • 216
        great advice, swaybars are a must. the car will handle so much smoother in and out of the tight corners and wide hi-speed turns.
        i recommend you go with the larger ones, most ppl would say they wish they had gone with something thicker.
        • Mike B.
          • Jan 2006
          • 987
          A nicely fabbed 4-pt that is welded in place with removeable harness and diagonal is completely liveable on a street car. I'm not talking about a cage.
            • 34844
            sure, great, as long as you don't have friends, a dog, or anything like that. :p
            • themitchster359
              • 654
              sweet, i was looking at the eibach set up...20mm in the front and 16 in the back
              • erik325i
                • Jan 2005
                • 3567
                That's not true. I'm not a big fan of thick roll bars at all. It's better to get stiffer springs than thick rollbars in my opinion.
                -Erik
                • moatilliatta
                  • 6157
                  -Erik
                  Ive herd the same thing, at least for auto-x.
                  @Zakspeed_US
                    • 34844
                    -Erik
                    it depends on the surface you're driving on, but yea thicker roll bars are definitely not always better.
                    • alpinweiB
                      • 287
                      20mm in the front isn't that big. if you want a 20mm sway bar just pull one off of any 325is and i think even the stock 325 sway bar is 20mm. also the stock cabrio sway bar is 21mm in the front
                      just go real big and get the IE 25mm adjustable for the front
                      what exactly is sigworthy
