Hmmmm. When i initially installed my H&R race springs on the bilstein HDs i had on my car, it bounced like crazy. I assumbed the bump stop placement was different on the sports as the bouncing went away as soon as i installed the sports. Also would the longer tube change the bias of gas on either side of the valve. I've always felt it is a little easier to push down the last inch of compression then the first inch.
billly sport vs. HD?
www.gecoils.com
My euro 316 project Transaction Feedback -
On an e30, yes.
Here is info from a 1998 discussion about this, in the early days of the internet on a list called BMW digest. Credit to Pete Read who got it from Bisltein engineers, who won't tell you this anymore.
E30 3 series 325e/es, i/is, M3
(3 series 87-91, 318i thru 86, front has 30mm piston, P30)
rebound / compression force at 52 cm/sec
Newton pound-force
N lbf (0.2248 x N)
Front:
P36 0132 Sport 2220/850 499 / 191
(P30 0133 Sport) 2220/850 499 / 191
P36 0136 HD 2220/850 499 / 191
(P30 0128 HD) 2220/850 499 / 191
Rear:
B36 2027 1475 Sport 1650/565 371 / 127
B36 2028 0720 HD 1650/565 371 / 127
[SIZE=4]I have attached a picture of me pressing on a Bilstein sport next to a Bilstein HD,
okay. so for sure it will be fine to run HD's on lowering springs?
some of us are on a budget. hehe. i just want to make sure.
my application is simply for daily driving and ocassional spirited driving.
i have already ordered LowTec 60/35 mm springs.. so HD's okay?
thanx hellabad
-jeff
best modification to any car is a clean car.
-jeffComment
The prices aren't too different. Shox.com even has sports for cheaper.
If only the TCs would work, those are about half the price of HDs or Sports. Some of the E34 guys I've have ran TCs with Eibachs or when they run Vogtland they used OE Sachs.sigpicComment
I have never mentioned that the reason the sports (p36-0335) are recommended for "shorter springs" to satisfy the TUV laws in Germany, where the spring is not allowed to come loose when the car is jacked up.
Thats why the sports are shorter when the struts are extended (not as far) but not when the car is on the ground.
If you already have the HD, just go ahead and use them, and if you are feeling the tiniest bit fancy, you can trim the internal bumpstops which is easy .Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
Ground Control Gallery
The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
and thus the spread of misinformation starts. great job hellabad.
might want to clarify that there is a reason you run sports with a higher drop race spring. before all the kiddies run out and buy twin tubes because you told them there is no difference between sports and any other bilstein.
i refuse to believe that the sports and hds are identical in performance. proof of this here:
i can understand running a .5" drop eibach or h&r on a HD. but h&r race or ie3s i dont see how its possible, safe, or cost effective.Hmmmm. When i initially installed my H&R race springs on the bilstein HDs i had on my car, it bounced like crazy. I assumed the bump stop placement was different on the sports as the bouncing went away as soon as i installed the sports. Also would the longer tube change the bias of gas on either side of the valve? I've always felt it is a little easier to push down the last inch of compression then the first inch.Comment
None of the e30 Bilsteins are twin tube, which is what WE are discussing.and thus the spread of misinformation starts. great job hellabad.
Originally posted by einstein571227260Hmmmm. When i initially installed my H&R race springs on the bilstein HDs i had on my car, it bounced like crazy. I assumed the bump stop placement was different on the sports as the bouncing went away as soon as i installed the sports. Also would the longer tube change the bias of gas on either side of the valve? I've always felt it is a little easier to push down the last inch of compression then the first inch.[/I]
I have a shock dyno and an armload of e30 Bilstein struts, damping numbers from Bilstein engineers, and you have a "QUOTE" button on an internet message board and a sarcastic demeanor.
I am trying to tell a guy that it is ok to use HD on his car to save money.
Jay MorrisHere is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
same springs in the rear, iirc.
maybe a small difference in rate, but height is too close to count. Plus, I have an 89i with late rear fenders (lower), it looks lowered in the back as is!1989 cirrisblau-metallic 325iComment
