Camber Plate options
  • graphikg
    • Jan 2008
    • 1614
    I have Billys sports and H&R race, and am thinking of getting a set of camber plates. I was going to go GC but found a good set of IE to go with my Billys for a nice price. I know IE makes some good stuff so I was wondering if anyone had experiences with these. I do a little track, but like to go to the AutoX more often. I searched around and found plenty on GC and Vorshlag but not on IE. Tell me what you all think.
  • alpinaclone
    • 820
    I too am curious if the IE camber plates are any good. I know IE are a pain to deal with, so I don't want to hear about that type of shit. :)
    Matt
    • moatilliatta
      • 6158
      gc is a pain to deal with also...
      @Zakspeed_US
      • JGood
        • Jan 2004
        • 7959
        I went with Ruff plates from Carr Industries for my H&R Race/Bilstein Sport setup. I'm very happy with them.
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • Hellabad
          • 807
          Check your PM, I thought I knew all of the G.C. e30 customers in Louisville, and I don't recognize your name.
          Jay
          Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
          Ground Control Gallery
          The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
          • ddavidv
            • 344
            IE's were pretty much the only legal option for Spec E30 for quite awhile. Thus, I own a set. They come with ZERO instructions on how they go together and it is confusing, but the SE30 racer's site has photos and instructions buried in one of the threads that you can search for.
            They are ok for the money, but if I had to do it over again, I think the ones from CARR would be legal and I'd go with those. The trick is you have to find ones that work with the stock spring perches. Not all of them do.
            I was able to avoid the whole IE non-existent customer service experience by buying mine through Flying Brick. They are very helpful and sometimes their prices are even less than IE's!
            • g22
              • 274
              i have Vorshlag, pricey but very nice.
              • DSP74
                • Nov 2007
                • 1121
                rsafier used IE plates on his turbo'd SM autox car with 285's.
                Alex Shipkov uses them too.
                My understanding is you don't gain alot of negative camber vs say a Ground Control plate. And maybe no caster adjustment. Not sure there would have to check for yourself.
                88 325is
                • graphikg
                  • Jan 2008
                  • 1614
                  Thanks for all the help everyone. I think I will go with the IEs since the price seems good, but which should I go with? I know I want adjustable ones but which ones exactly? My car is mostly a daily driver but I go to the AutoX here and there sometimes. So which would be a good choice? Trying to decide between what is in here... http://store.nexternal.com/shared/St...t=products.asp
                  First page in steering and suspension.
                  • Hellabad
                    • 807
                    There's several camber plates in there, which ones were you looking at? If you have stock diameter springs, some of those items arent what most of us would consider a "camber plate" because all they do is move your stock upper mount over to the side, and you can do that for cheap with a drill bit.
                    jay
                    • graphikg
                      • Jan 2008
                      • 1614
                      I was looking at the Spec e30 adjustable ones that apply to springs with factory diameter. I have H&R Races so I am assuming these would work.
                      • moatilliatta
                        • 6158
                        Jay
                        PM Returned.
                        @Zakspeed_US
                        • ddavidv
                          • 344
                          Yup, same setup I have.
                          They will give you 2.5-3 degrees max negative camber depending on the car. I would probably not do more than 1.5 for a street driven car to save the tires. It does make a difference even at 1.5 which are where mine still are. Don't be surprised when you can't fit all the bolts they provide within the strut tower opening...normal. Also, you must use the dopey washers they come with or the steering will bind (yeah, found that one out myself).
                          • graphikg
                            • Jan 2008
                            • 1614
                            So would you reccomend these plates with the springs you have? Are you satisfied with your decision or do you think you would go another route next time?
                            • Jesse30
                              • Jan 2007
                              • 3936
                              i have the ie street track adjustable camber plates and i highly recommend them for street use, the spec camber plates we offer may be too harsh.
                              the street track camber plates have a spherical bearing in a machined bearing holder surrounder with urethane and then placed into a second housing which then bolts to the top plate. No, they are not made in china.
