TRUE e30 rear coilover setup..
  • einstein57
    • Jun 2007
    • 10780
    The back end sits kinda high with the adjustable perches imo. I would just have a adapter plate machined for your springs. That would make things considerable cheaper.
    www.gecoils.com
    • AndrewBird
      The Mad Scientist
      • 11898
      Originally posted by peerless
      I have worked as a machinist in the past making parts for aerospace and military aircraft. I can tell you without a doubt that threaded collar is the crappiest machining I have ever seen. I mean the picture speaks a thousand words.
      The feeds and speeds are way cranked up for mass production. The quality of the steel itself is suspect too. You can see on the inside where the metal is smeared from blown out tooling, lack of coolant, too fast of a feed rate. And the threads, look at all the porosity in the threads.
      Agreed x1000000. Those threads are so torn up. They should be glossy smooth. And I'm pretty sure that is aluminum, not steel. Hard to tell from the picture though. The round washer looking thing is definitely aluminum.
      Man, the things I could make if I had the tools...
      • sticksdaman
        • Apr 2005
        • 2987
        or you could just order shorter springs and keep your adjust-a-bility.
        just a thought
        Originally posted by ebelements
        Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
        • el_gringo
          • Mar 2008
          • 299
          Originally posted by Aptyp
          Moton
          psh. moton my ass.
          Ksport dude. $1300 bucks. a friend has a set for his 240... for a daily they are good. but he started tracking his car every weekend for 2 day events for the past year... kept up so far.
            • 34844
            IE sells ground control sleeves/perches without the rest of the kit.
            That rear design is NOT safe of matter what you do. The only way you could make that work is if you limit rear shock travel. Reinforcing tower is a given, but flipping the shock upside down, and cutting piston short would be what you'd want to do. If you do that, you may as well redesign rear suspension or get e28.
            those are NOT ground control adjusters - if ground control made shit like that, I doubt as many people would be running them.
            • el_gringo
              • Mar 2008
              • 299
              wait.. i thought you can buy just perches alone through GC?
              • el_gringo
                • Mar 2008
                • 299
                you can. its amazing! go to gc's website, search for perches. if you cant find them (because they sell perches alone for other cars) give them a call and make it work. everything has a price!
                • SA E30
                  • 1248
                  Not quite standard though. They were Bilstein E36 Group N shocks, with a machined sleeve fitted.
                  They use a 60mm id spring...
                  Now if only the buggers fitted inside the rear wheel well... oh well Guess nothing some new sheetmetal can't fix (aka, making new top mounts and shock tunnels.
                  • el_gringo
                    • Mar 2008
                    • 299
                    exactly. anything will fit if you want it to.
                    • loonibab325i
                      • Dec 2005
                      • 770
                      gah, i searched perches on their website and all i saw was their conversion kits?? I also called GC and they said they wont sell me parts by them selves.. i'll try again.
                      s52 0-150mph & more http://www.youtube.com/loonibab325i
