Tire rubbing against swaybar.
  • Melon
    • Mar 2018
    • 1311
    When my wheels are on lock, the inner sidewall is making contact with the swaybar, where it bends from going under the car, to the mount.
    I have 205/50/15 on Kosei-K1 ET25 wheels.
    H&R Sway bars, with IE sway bar reinforcements.
    Z3 2.7 Steering rack.
    Offset M3 control arm bushings
    I tried a 10.5mm spacer, and it makes the wheels stick out about 1/2" past the fender, I have a 3mm on there right now, and it's not enough. I doubt a 5mm spacer would do much.
    Anyone else had this issue?
    I do things.
  • e30davie
    • Apr 2016
    • 1788
    How wide are those wheels? 7" ?
    • Melon
      • Mar 2018
      • 1311
      15x7, correct.
      I do things.
      • agent
        Vice Grand Pubaa
        • 7960
        General Discussion is not a catch-all; please do not ask technical questions there. If you don't know where to ask your question, post it in General Technical and we'll move it to the appropriate subforum if necessary. Thanks in advance.
        Originally posted by kronus
        • Melon
          • Mar 2018
          • 1311
          I posted on my phone, and scrolled forums until I saw the 'For Sale' section, which is usually the last section on most forums.
          I done did a derp, my bad.
          I do things.
          • agent
            Vice Grand Pubaa
            • 7960
            All good. Everyone gets my boilerplate reply when I have to move a thread - I don't discriminate.
            • E30SPDFRK
              • 5713
              H&R front sway bars are bent wider than the factory bar, the rubbing is normal.
              Byron
              Leichtbau
