hub centric rings without taper?
  • peytonracer4
    • May 2011
    • 524
    I have the 16" style 5 wheels with a fill and drill. The hub centric ring installed is tapered and doesn't sit on the front hub. the rear hub lip is fine because it extends out slightly farther. Anyone know of a source to get non tapered or BARELY tapered rings? The only way to get no vibrations with mounting is with pure luck at this point.
  • 82eye
    • Jan 2009
    • 2102
    wasn't someone turning rings and offering them on the site for that specific app ? i remember seeing it somewhere, maybe on Bfc.
    • Digitalwave
      is a poseur
      • 6299
      That sounds like a poor fill and drill if there is no chamfer on the wheel hub. The hubcentric ring probably isn't your issue.
      RISING EDGE
      • hopeful
        • Dec 2012
        • 118
        Check this out
        Upgrade your 4x100 redrilled wheels with our all-in-one hubcentric adapter and spacer kit. Designed specifically for adapting BMW wheels—such as 16” and 17” Style 5s—to E30 BMWs and other vehicles with a 4x100 lug pattern and a 57.1mm hub. Kit Includes: (2) 12mm spacers with a 57.1mm hub bore and options for 74.1mm or
        Also, I'm not really understanding what your saying. I'm wondering if your saying the front ring is sitting well in the wheel but it's not center on the front hub?
        I'm also wondering if the same effect can happen with a reducer ring pushed into a cb72.5 spacer that already has a centering ring.
