Ronals came in... what tire size?
  • Fuddy
    • 123
    Right now on the Ltw replicas i'm running 205/40/17...
    what is a good size for the ronal ls's?
  • Mystikal
    Wheel Fitment Expert
    • 9602
    225/50/15. Anything else would be uncivilized.
    • Digitalwave
      is a poseur
      • 6300
      225/50-15, man style meat.
      RISING EDGE
      • RCWells
        • 3589
        Kinda depends on tire choice too. I agree with the 225s, but tire dependent. My Bridgestone 205s look ridiculously balloony. If you were to go with 225s, it would be that much worse. Try to find a tire with a lower profile sidewall, and the 225s would be fine. I will eventually go with a 225 myself, but NOT in a Bridgestone.
        [THE 501 club - Founding Member]
        • Skafrog
          • 1732
          225/50/15 ES100's
          When you force a car off the road because of the spray shooting off the tires in the rain, you have succeeded.
          NASA MidSouth TT Director / GTS2 #018
          Mods: Coastal PS Fluid, 10w40 Oil
          Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
          • Mystikal
            • 9602
            BTW, some width 225's will not fit, they will rub the strut in the rear. The S-03's are of such, look up the width on these and make sure whatever tires you choose aren't quite as wide.
            • Jon325i
              • 6934
              Toyo Proxes T1-S are the same....too wide in a 225 width. Yokohama ES100s and Dunlop SP8000s will fit since Ronal offers them with the LS as a wheel/tire package. I'm sure there are some other brands of 225/50-15s out there that fit.....I'm just not aware which ones.
              Jon
              Rides...
              1991 325i - sold :(
              2004 2WD Frontier King Cab
              RIP #17 Jules Bianchi
              • trent
                Jon
                I ran 225/50/15 T1S on my 15inch euro baskets on my 89 and didn't have rubbing anywhere.
                • Mystikal
                  • 9602
                  Jon
                  Euro baskets are 7" wide versus 7.5" on the Ronals, so the rim pulls the tire .25" inwards.
                    • 34847
                    not to mention the ronals are about .28" closer to the fender and .22" closer to the strut.
                    • BS87
                      • 1606
                      :rofl:
                      • trent
                        Jon
                        so run a spacer....lamers
                        • Mystikal
                          • 9602
                          So then add the cost of spacers, bolts, plus the fender rolling you'll likely need...just to run a certain tire model?!
                          • trent
                            uhhh yea...been there done that numerous times.
                            cheap bastards
                            • Fuddy
                              • 123
                              ugh... spacers :o
                              another question... are the ronals hubcentric?
