Offset for 16x8? Give me ideas please
  • e30excel
    • Oct 2004
    • 73
    I was thinking of running a 16x8 wheel with a 225 width tire. I was trying to get an idea of what offset I should try to get. I want the wheel/tire to be pretty flush with the fender for optimal stance. My guess is a 20mm offset? but I am not sure...Any ideas???
    kind of the idea is like team solos e30 http://teamsoloracer.com/
    www.driftunit.com and www.excelfundamentals.com <--- supporter and admin
  • Rich V
    • Oct 2004
    • 69
    20mm sounds about right.
    • Jon325i
      • 6934
      What year is your E30? The earlier cars (87s and before) have a different shape/size to the rear wheel arches which can accommodate fatter rubber more easily than the newer cars (i.e. plastic bumpers).
      Jon
      Rides...
      1991 325i - sold :(
      2004 2WD Frontier King Cab
      RIP #17 Jules Bianchi
      • Digitalwave
        is a poseur
        • 6293
        20mm with 16x8 and 225's will probably rub the fenders. I would shoot for 24-26mm offset.
        RISING EDGE
        • Mystikal
          Wheel Fitment Expert
          • 9602
          This guy's on the ball. You will likely still have to do just a bit of minor rolling on at least one fender though.
          • M42Technik
            • 9781
            Its hard to find a 16x8" wheel in such a smaller offset.
            BBS RS003 16x8" has an offset of ET12. 16x7.5" is ET19. 16x7" is ET25.
            16x7" is stock size, the other two sizes above will have to be custom made with larger lips bought from Kodiak...
            I personally am trying to get 16x8" BBS RS003's and roll the fenders as stock looking as possible, but at ET12 I dunno...
            Good luck in your search.
            Reminiscing...
            • Brew
              • 3060
              I think they might hit the strut tubes up front with that offset.
              That said, I would go with et25 and run small spacers up front if necessary
              '91 318is
              • M42Technik
                • 9781
                I just found this E30 actually...BBS RS001 with 16x8.5" with an offset of ET22.
                16x9" in ET15 in the rear. Thats just about perfect. Link to other pictures below...
                Reminiscing...
                • Rich V
                  • Oct 2004
                  • 69
                  Those RS001's are simply the best wheels for the E30 IMO! Too bad they cost near as much as my E30 also. :x
                  • M42Technik
                    • 9781
                    BBS RS003's are the same and just as good. ;)
                    Reminiscing...
                    • Jon325i
                      • 6934
                      I think you got that backwards. With a ET20 offset, the wheels are being pushed out farther (towards the fender's edge). Running something like a ET30 offset would pose the rubbing-against-the-strut issue.....not to mention tuck the wheels inside the fender wells.
                      Someone validate this.....I'm OD-ing on acetaminophen.
                      Jon
                      Rides...
                      1991 325i - sold :(
                      • Brew
                        • 3060
                        Jon
                        Nah, I was saying that et25 would rub the strut tubes. et20 would probably be about right for a 16x8, but would require some fender rolling for sure.
                        '91 318is
                        • e30excel
                          • Oct 2004
                          • 73
                          So I am getting some mixed signals...
                          Et20 or Et15? I am going to run 16x8 with 225 width tires...and i will slightly roll the fender as needed.
                          I am thinking Et20 still...
                          • e30excel
                            • Oct 2004
                            • 73
                            and one more question...should I run 225, 215, or 205?
                            I see a pic above of the conv. e30 and the front is 205 on 8.5inch wide and it isnt stretched too bad. So I was thinking a 205 or 215 on 8inch wouldnt be a bad stretch.
                            thoughts...
                            *EDIT* and yes its the early model (1986) e30
                            • Brew
                              • 3060
                              et20, 225/45
                              '91 318is
