Inside tire wear
  • george graves
    • 20003
    thank you. This thread is getting printed and put on the wall-o-parts to order.
    Originally posted by Matt-B
    • erik325i
      • Jan 2005
      • 3567
      ^Will any guy that's been to alignment school be able to jump right in and set up the car with those eccentric bolts? Or do you need to take it to someone with experience with it? Or the right rig?
      Those are kinda standard part's aren't they?
      Any alignment shop should be able to do it, but I'd recommend using a shop that has experience doing this.
      You need to explain to them that you have adjustables, or else they might not know to do it.
      There are no special skills needed to do the alignment after the kit, but because of the very limited space, you will need to use a modified wrench to be able to tighten the nuts properly. If you provide the shop with a wrench that is already modified (or willing to be modified), it will make their job much easier.
      I'd recommend having them mark all of the adjusters/nuts with a paint pen so you can visually check them in the future to make sure they did not move or loosen up. If the nuts are not tightened enough, they will loosen up, fall off, and cause extremely weird handling. ask me how I know...
      • george graves
        • 20003
        What's the dealieo with the wrench, essay? Bent? Or thinned homie?
        • erik325i
          • Jan 2005
          • 3567
          I ground mine down in a couple places to allow for more movement. If I remember, I'll take a picture of it tomorrow when I'm at work.
          Erik
          • E30Idea
            • Mar 2007
            • 2196
            Erik
            Subscribed
            ** Lot's of M20 turbo parts for sale.**
            Turn key track car.
            http://www.r3vlimited.com/board/showthread.php?t=222066
            • erik325i
              • Jan 2005
              • 3567
              Here's the wrench I modified to do my last alignment. Without doing that, there is not enough movement to be able to tighten the nuts all the way.
              I also have one of these guys, which sometimes helps at certain angles.
              • george graves
                • 20003
                Nice - thanks for going out of the way to snap a pic.
                • Yeee30
                  • Nov 2005
                  • 799
                  erik325i is right... without a modded wrench its pretty much impossible to adjust and/or tighten a rear subframe weld-in kit. i know from working at a shop and dealing with customers that want that on there car...
                  [PAKSIW]
                  20D .........
                  vmwerks :up:
                  ryan gmw :up:
