Painting, polishing, repairing wheels
  • nickmp0wer
    • 1427
    I just got some 15" weave and i still need to check to see of they are straight, but if they are im going to be repainting the centers gold and polishing the lips. Some of the lips are curb rashed pretty bad but i dont think i could use body filler to repair them since i will be polishing them. should i just file them down? Any masking tips?it seems as though they were masked PERFECT before and i would like to be able to do that again. Do wheel shops have any special thing they use for this? i wouldnt think they still use tape.
    perfect perfect perfect masking
    someone didnt know how wide their car was!!!
    some more gold then others
    • 34847
    that's a lot of rash.. I considered polsihing mine but I ended up just filling in the rash and painting them. good luck.
    • nickmp0wer
      • 1427
      yeah that seems like it would be pretty easy, but i think they would look odd with gold painted centers and a silver painted lip.
      • Dave
        E30 RAT
        • 11675
        What paint are you going to use on the centers? I have a set of gold baskets that I am picking up soon and I may need to refinish them. The Wurth gold (if you can find it) supposedly is NOT a good match.
        Current Cars
        2014 M235i
        2009 R56 Cooper S
        1998 M3
        1997 M3
        • nickmp0wer
          • 1427
          you mean the color isnt? i am going to be painting the whole things so it shouldnt matter unless the wurth paint just looks bad. I want it to be bright like the one in the upper right hand corner
          • nickmp0wer
            • 1427
            should i just use the dremel to try and smooth out the curb rash? I recently found out that one of the rims had pretty bad bends on the rim on both sides. It was nothing a hammer couldnt fix! lol
            • Digitalwave
              is a poseur
              • 6300
              Curb rash that bad is going to be very hard to repair yourself. I personally would have those professionally refinished.
              RISING EDGE
              • nickmp0wer
                • 1427
                professional what?
                :D
                I also hammered back some bends. I wish i would have taken more pics so you could better see what they were like. 2 of the rims had bad rash almost all the way around. That rash is no more!!!!
                • kylebes1
                  • May 2004
                  • 2804
                  are they level? look nice from here
                  • nickmp0wer
                    • 1427
                    for the most part they are level. although there are a couple huge gouges i had to grind down pretty far. If you stand them up and look at them from almost straight down they wont look perfect, but all other angles are good
                      • 34847
                      I figured out that small blemishes don't matter, nobody will ever get close enough to your wheels to see them (especially if you are moving)
                      good work on cleaning them up, but you're going to have to work on that fninsh..
                      • nickmp0wer
                        • 1427
                        yeah im going to be applying the paint remover tmr, then Im going to repaint them. I know I should clear the paint, and Im pretty sure i should clear the bare metal after i polish it. Is that right?
                        also WTB CENTER CAPS!!!
                        Im probably going to order all the wurth paint and shiz on monday. Then I think i will do a test run on my spare.
                        • permit
                          • Mar 2005
                          • 3363
                          I have 4 centercaps for those. They're blue, but if you're painting, it doesn't much matter. They say BBS instead of BMW on the center. $100 shipped.
                          • nickmp0wer
                            • 1427
                            damn, i just payed 300 shipped for the wheels, i dont wanna pay 1/3 that for the caps.
                              • 34847
                              you shouldn't have to, in fact I wouldn't because you will be able to polish it up later if needed. the aluminum will 'oxidize' creating a protective layer all on it's own. clearcoat will likely flake off/chip/scratch.
