Widest Cheapest lightest setup
  • Jean
    • 18228
    Originally posted by CrazyB
    So I am on a hunt for wider and bigger wheels.
    The wheels will be for an autocross car.
    SO what would you guys recommend. I am looking into something in a 16x9 or 17x9 sizes to run 245 or 255 tires. I will be adding flares to clear them. But first I need to find a set of wheels
    What class do you intend to run in, SCCA/BMWCCA ?
    Might want to double check what size/width is allowed.
    • z31maniac
      • 17566
      Originally posted by Brian D
      Just a reference, the Apex wheels do not fit with the Massive race front kit. They interfere with the calipers on the inside edge.
      Would a 3mm spacer fix that?
      www.gutenparts.com
      • Brian D
        • Mar 2006
        • 832
        I was going to buy them from a local guy, when we mocked them up it was dark, but as I remember it was more along the order of 1/4" or slightly more needed. I was pretty disappointed.
        1973 Bavaria
        • straight6pwr
          • Sep 2004
          • 3450
          Originally posted by Jean
          imho there is no point in getting 17x8 wheel to only run 235 tire when you can run a quality/sticky 225 tire on 15x8?
          15x10 would be the ideal size as there is a 275/35 sticky tire in that size, but the wheels are limited. you'll either have to buy the above mentioned $200 wheels and add $ for adapters/spacers OR pay about $500+ per wheel for custom size / spec wheel .
          personally, i like the snappier response of the short sidewall on the 17 vs the 15 for the same tire width.
          • moatilliatta
            • 6157
            Dforce
            @Zakspeed_US
            • CrazyB
              • 420
              I was wondering for 17x9 anyone know the best offset to run.
              How big of a spacer needed to run 17x9 with +23 et
              fenders are not issue as I can run flares
              AutoCross Photos!!https://picasaweb.google.com/eugenes18t
              • CrazyB
                • 420
                Also what would be best offset on 17x9 to run a 245 or 255 tire
