Tire Question: 185/60/R14?
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    Are 185/60/R14 tires ok to use on 14 inch bottle caps on an 87 325i?
  • parkerbink
    • Jun 2004
    • 10138
    Stock was 195 65 14 this site recommends remaining within 3% of stock and this change is over 5%
    http://www.1010tires.com/TireSizeCal...?action=submit
    Stock Tire - 195/65R14 >Search Tires Tire 1 - 185/60R14 >Search Tires
    Section Width: 7.67 in 195 mm
    Section Width: 7.28 in 185 mm
    Rim Diameter: 14 in 355.6 mm
    Rim Width Range: 5 - 7 in
    Overall Diameter: 23.98 in 609.09 mm
    Overall Diameter: 22.74 in 577.59 mm
    Sidewall Height: 4.99 in 126.74 mm
    Sidewall Height: 4.37 in 110.99 mm
    Radius: 11.99 in 304.54 mm
    Radius: 11.37 in 288.79 mm
    Circumference: 75.33 in 1913.3 mm
    Circumference: 71.43 in 1814.3 mm
    Revs per Mile: 867.3
    Revs per Mile: 914.6
    Actual Speed: 60 mph 100 km/h
    Speedometer1: 63.2 mph 105. km/h
    Speedometer Difference: - Speedometer Difference: 5.453% too fast
    Diameter Difference: - Diameter Difference: 5.18%
    • RobertK
      • Jun 2005
      • 5864
      So these would be bad for my car?
      • Joe318is
        • Sep 2005
        • 6451
        Whats your plan for them?
        Thats a good size for winter use, but if your looking for a factory replacment go with 195 65 14's. If you looking for improved handling/performace by ways of a wider tire, go with 205 60 14's
        Originally posted by vlad
          • 34847
          those are way too small. try something with a higher aspect ratio.. like 185/70-14. even 195/60-14s are small (I wish I had gotten 195/65).
          • arsevader
            • May 2005
            • 1025
            They are too short though. As Nando says, 185/70 is a better size.
            195/60 was the original OEM size for the E30 then they bumped it up to 195/65.
            James
            • Rigmaster
              • 3464
              What do you mean by "bad" for your car?? It won't hurt or damage anything- it will make you speedo read incorrectly- so be aware of that- though in this case, the speed you are actually travelling will be lower than that shown on the speedo.
              Bret.
              • arsevader
                • May 2005
                • 1025
                Bret.
                Wouldn't it be the other way around though?
                The time it takes for the wheel to rotate 360 would be less but the speedo doesn't know that.
                James
                • Joe318is
                  • Sep 2005
                  • 6451
                  James
                  i thought it said 186 70 14....
                  • arsevader
                    • May 2005
                    • 1025
                    186 is an odd size eh. ;)
                    James
                    • Joe318is
                      • Sep 2005
                      • 6451
                      James
                      haha, oops..... EAD YOU HOMO'S
                      • parkerbink
                        • Jun 2004
                        • 10138
                        Right now I have 205 60 14's I like them here is what they work out to:
                        Stock Tire - 195/65R14 >Search Tires Tire 1 - 205/60R14 >Search Tires
                        Section Width: 8.07 in 205 mm
                        Rim Width Range: 5.5 - 7.5 in
                        Overall Diameter: 23.68 in 601.47 mm
                        Sidewall Height: 4.84 in 122.93 mm
                        Radius: 11.84 in 300.73 mm
                        Circumference: 74.39 in 1889.5 mm
                        Revs per Mile: 878.3
                        Speedometer1: 60.7 mph 101. km/h
                        Speedometer Difference: - Speedometer Difference: 1.268% too fast
                        Diameter Difference: - Diameter Difference: 1.26%
                        I have 205 50 16's waiting for me in L.A. here is their differance:
                        Stock Tire - 195/65R14 >Search Tires Tire 1 - 205/50R16 >Search Tires
                        Rim Diameter: 16 in 406.4 mm
                        Overall Diameter: 24.07 in 611.37 mm
                        Sidewall Height: 4.03 in 102.36 mm
                        Radius: 12.03 in 305.56 mm
                        Circumference: 75.61 in 1920.4 mm
                        Revs per Mile: 864.1
                        Speedometer1: 59.7 mph 99.6 km/h
                        Speedometer Difference: - Speedometer Difference: 0.370% too slow
                        Diameter Difference: - Diameter Difference: 0.38%
                        • kencopperwheat
                          King of Kegstands
                          • 14396
                          I'd get 205/60s
                          Originally posted by Gruelius
                          • turnofftheradio
                            • Apr 2005
                            • 448
                            I run those little tires. they suck, my speedo is off, my rpm's are too high on the freeway. They look really dumb in the big wheelwell. but they were free with lots of tread...
                            • RobertK
                              • Jun 2005
                              • 5864
                              That is the same reason I was interested. They are brand new and free.. guess I'll just wait it out and buy the right ones.
