Will they fit?
  • DarkWing6
    • Apr 2004
    • 7144
    Will they fit?
    I have discussed offset and tried to understand. I am looking at a set of wheels that are 15x7 with a ET35 offset. I think they will fit, but does anyone know for sure?
  • 2002maniac
    • 4260
    10mm spacer will do the trick.
    • parkerbink
      • Jun 2004
      • 10138
      Basketweaves are 30
      • DarkWing6
        • Apr 2004
        • 7144
        Will they rub without them?
        • e30frosh
          • Dec 2004
          • 2170
          My 15x8.5 are 33et...No rubbing, no spacers. 35et might be too close, but they may work without spacers...
          Every day I wake up we drink a lot of coffee and watch the CNN
          Every day I wake up to a bowl of clover honey and let the locusts fly in.
          Lobsterbacks attack the town again
          Wrap all my things in aluminum
          Beams of darkness streak across the sky
          Pink rays from the ancient satellite
          Every time I look out my window same three dogs looking back at me.
          Every time I open my windows cranes fly in to terrorize me.
          • Digitalwave
            is a poseur
            • 6299
            Originally posted by parkerbink
            Basketweaves are 30
            What's your point? They are also 14x6.5, completely unrelated.
            I honestly can't picture 15x7" Et35 fitting without rubbing the struts, but if it does fit, you will be stuck with 205 tires and it won't look very good.
            RISING EDGE
            • parkerbink
              • Jun 2004
              • 10138
              Whats up today TJ?
              Offset is part of his question, Basketweaves have an offset of 30.
              Ok?
              • Digitalwave
                is a poseur
                • 6299
                Different rim sizes and widths need different offsets... that didn't help at all is all I am saying.
                RISING EDGE
                • parkerbink
                  • Jun 2004
                  • 10138
                  Fair enough but it's not like I said I like pie.
                  • nitro325is
                    • 495
                    You should be fine assuming you'll be using a 215 or less tire. I have run many times 17*7 et40 with 215/40/17 with NO strut tower rubbing but does rub inner well under very tight turns.Yes car is also lowered.
                    • Digitalwave
                      is a poseur
                      • 6299
                      Here is another example of useless info. 17" rims give you much more clearance than a 15". The higher up you go from the hub, the more space between the rim and the strut you have, given the same rim width and offset.
                      RISING EDGE
                      • nitro325is
                        • 495
                        Wrong! How is that more clearence if the rim itself is getting closer to the hub tower? Also overall Diameter puts it within fractions of stock combination.So again how is that more clearance? Please research or consult with the OG that was harsh but gave correct info.
                        • Digitalwave
                          is a poseur
                          • 6299
                          The strut angles in towards the car. The bigger the rim, the farther it is from the strut. I am not talking about the overall diameter, I am talking about the inside clearance of the rim. A 17" has much more clearance than a 15".
                          RISING EDGE
                          • BMW BMXER
                            • 2325
                            My rims are 15in, 6.5 inchs wide, and have an offset of 33. I run 205 tires. I don't rub but the space between my wheel and the strut is paper thin.
                            Sold it.
                            • Garageaholic
                              Freestyle Fabricator
                              • Dec 2005
                              • 5204
                              http://www.1010tires.com/WheelOffsetCalculator.asp
                              Helps alot .... for relative differences in wheels...
                              Recent Rebranding!!
                              E30 SM62/S62
                              E30 M60 V8
                              E30 M30 Big 6!
                              Instagram.com/garageaholic
                              Youtube.com/garageaholic
