Help me choose a wheel
    • 34839
    Originally posted by MJTSUB
    So since the BBS wheels have a width of 7" and an ET of 38 will I have rubbing issues?
    no, they just won't look very aggressive because they will sit pretty far inside the fenders.
    • Mystikal
      Wheel Fitment Expert
      • 9602
      I was in the same shoes as you this summer. I had to choose between real Volk TE37's (13lbs, $1700 for the set) or fakes (14lbs, $500 for the set). I chose the fakes because its silly to put rims that are half the value of the car when you really think about it.
      LOL, I bought a set of gold/silver 5x100 BBS LM's last summer (planning on adaptors) right after I sold the RS'. I quickly came back to my senses and cancelled that shit.
      • Mystikal
        • 9602
        Originally posted by nando
        I agree.. to a point. for a 7" wide wheel you'll probably want to be at about ET 28. for a 7.5" wheel you'll want to be around ET32. you don't want to go too low or you'll have trouble rubbing in the rear, even with stock sized tires. I'm currently using a 24mm offset with a 7" wheel. with a 10mm spacer on the BBS you could run a wider tire without worrying about the fenders.
        I've seen 16x7.5" ET35 wheels on an iX (test fitted Borbet Type E's I briefly had last summer), and there was still quite a bit of room front and rear. The extra half-inch of width only equates to 6mm further outward protrusion given the same offset. ET30 7.5" would be the same as you have.
        And he can't run wider than 215's on that wheel anyways, so he may as well push them to the fenders.
        • Mystikal
          • 9602
          Originally posted by e30evolution
          didn't know you could get RGR's in 4x100
          They only started in '05.
          • Digitalwave
            is a poseur
            • 6293
            Are you sure? Maybe just the silver ones. I know I have seen the diamond black ones for a while on Tire Rack, but maybe I am just crazy. m3ntal kev has the diamond black ones on his white non-M.
            RISING EDGE
            • Mystikal
              • 9602
              The Diamond ones. I know they weren't available because I was sourcing the paint for my RX's (identical spoke design) to make faux RGR's because they weren't made yet (mid-'04).
              Kev bought those wheels last year for the Mini, then put them on the 318. He's local to me.
              • Tvan
                • 780
                Diamond RG-R's would look really nice on a d-shwartz car, I approve.
                • bmwm3n528
                  • 3654
                  Did you ever get the Diamond Black paint? Wouldn't mind doing my RXs the same.
                  Trevor Ely
                  '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
                  '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
                  • Digitalwave
                    is a poseur
                    • 6293
                    Hmm, I never noticed that the spoke design is the same but you are right. For some reason the RG-R's are so much hotter to me.
                    RISING EDGE
                    • bmwm3n528
                      • 3654
                      Only difference i'm aware of is, of course they're forged. The other, the edge of of the lip is not flat on the RG-Rs.
                      RG-Rs are one of BBS's strongest wheels in production, from what I am told from a BBS PR.
                      Trevor Ely
                      • Mystikal
                        • 9602
                        Nah, never found the Diamond Paint. To be truthful I didn't really scour the world though, just local places.
                        • bmwm3n528
                          • 3654
                          Well, BBS is not too far from us...might try them. 16" "RG-Rs" would be sharp.
                          Trevor Ely
                          • workaholic
                            • Dec 2005
                            • 172
                            The Kopis aren't really like though.
                            And, in my opinion, an iX is going to need to be sitting pretty low to make 17's look good.
                            where did you find those fake te37's for so cheap?
                            As for the thread, If you got the dough i would go with the diamond black RGR's otherwise go with the kopi's and some good rubber
                            Tom
                              • 34839
                              stock ride height? because I rub with 205/55-15's and a 24mm offset..
                              • Mystikal
                                • 9602
                                Same setup as you.
