Tire rubbing strut issue
  • AndrewBird
    The Mad Scientist
    • 11898
    Use washers to space the wheel out to determine what size spacer you need.
    DO NOT USE WASHERS IN PLACE OF SPACERS.
    Only use them for testing.
    • E30SPDFRK
      • 5703
      R888 are known to be one of the widest running street tires per size. Check how bad it is rubbing before you drive it much more, if it's really bad you could wear through the sidewalls and have to buy them over again.
      Byron
      Leichtbau
      • Merlin8
        • Apr 2013
        • 160
        Can this issue be corrected by camber plates? I have ground control street touring
        • Merlin8
          • Apr 2013
          • 160
          So I was able to take a look and there doesn't seem to be any rubbing, its close though, but it definitely sounds like it. Any idea what it could be? Like I said, it begins at aprox 25mph and doesn't stop until dead stopped.
          • Hellabad
            • 807
            I recommend being able to slide a pencil (5mm) between the tire and the strut. If you can fit a pencil in there, it probably is not the tire rubbing.
            Can you just rotate tires and see if the noise changes? its probably time to do that anyways.
            Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
            Ground Control Gallery
            The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
            • Merlin8
              • Apr 2013
              • 160
              Originally posted by Hellabad
              Maybe you had spacers before and they left them off?
              PS. If this is the right answer, please name your baby after me.
              Haha. BTW Hannah was born 12/4/15 945pm. Thanks for all the good words
              • Merlin8
                • Apr 2013
                • 160
                So I had a chance to get the car on a lift. The tires are not touching, bit very close. The little hairs on the tire can touch it and no displacement when on the ground. Could it potentially be rubbing on at different speeds? Is it just tire noise? I love the grip with the 318i, but not sure I can stand the noise for that long.
                • blazinxpk
                  • 839
                  so how much clearance do you actually have? Under load the entire assembly flexes, if there is barely any clearance then it it possible that during certain turns your tire rubs the strut.
                  My setup: 15x8 +20 225/45/15. If I use a wheel weight that goes on the edge of the lip it hits the strut in the front under load if i turn hard enough, when i drove straight nothing happened. Therefore, i have to use a stick on weight that goes on the barrel to fix this issue. Maybe you have this issue??
                  Another issue can possibly be your brake dust shield is bent and rubbing the rotor. Check to see if the shield is bent from its original position and bend it back if you have to.
                  • Merlin8
                    • Apr 2013
                    • 160
                    I have the stick on weights. It occurs on strait driving. Sounds kind of like a CAI.
                    • Northern
                      I like cupcakes & sh!tboxes
                      • 5231
                      No, that won't space your tires out. If it happened after installing R888's, it is because they're wider. R888's are without a doubt wider than those pedestrian KU25's.
                      What are your wheel specs?
                      Originally posted by priapism
                      Originally posted by shameson
                      • Merlin8
                        • Apr 2013
                        • 160
                        Thanks for all the input
