Originally posted by JuanPabloBongto
View Post
This is a sticky topic.
Originally posted by The Fast One! View PostThis question is for the e36 and not e30 but BF.c is not that much help.
I have a e36 m3 with BBS rx 17x8 wheels ET 38
I want to run 245/40-17 in the front but don't know if I will need spacers or not.
any help would be much appreciated.
If not, then no spacers needed. It just barely clears.
Funny thing is, my E36 fitment knowledge is easily 75% as in-depth as my E30 brain matter, which is realistically very powerful. But frankly, just keeping up here is a full time job. Plus, E30 guys are where my heart is, screw the E36 crowd. :p
Originally posted by hispeedimports View PostHI,
I am running 15x8 wheels with 215/50R15 BF tires, I am thinking in running a 225/45R15 Toyo R1R, this tire is not available in 225/50R15,
will the 225/45R15 be a good choise being around 23" tall or is it too small?
Thanks, Mario
I don't have coilovers but I do have bilstein sports with H&R race springs. so it is a low set-up. If you think I might need spacers, do you have any recomendations on some good but not too overlypriced wheel studs?
I love the e30 guys too, its hard not too. I wish I still had mine at times.
Thanks for all your help!
Mike Fritz
Originally posted by Mystikal View PostI believe it was your PM i just responded to? In any case, either spacer will work 100% fine.
Thanks for replying to my previous question.
I just purchased the 15mm spacer with longer bolt from ECS Tuning (http://www.ecstuning.com/BMW-E30-318...cers/ES260065/) It looks like the length of the lug bolt is longer than it is supposed to. It is hitting the hub for both front and rear when tightened properly.
I measured the longer lug bolts and it is 40mm.
My question is:
- is 40mm the correct length?
- is it safe to have it replaced with 35mm?
This is how I measured the lug length:
Thank you.
Originally posted by Mystikal View PostNot too small at all, I'd go as far to say that more E30s are running ~23" tires (usually 205/50/15 or 205/40/17) than the proper stock diameter. Aside from the aesthetic change and almost imperceptible gearing shortening, there is no difference.
Thanks, Mario
sigpic340hp V8 e30 FINISHED!!!!!
Quick vid for ya ;) http://www.youtube.com/watch?v=vp5Eaf8xOgM
NEW One on the track :)
http://www.youtube.com/watch?v=K-AX5SzSLnk
Cleaning up some 911s and Jap turbos
http://www.youtube.com/watch?v=Ad79wsLdle4
hey, im looking into a set of wheels for my 89 is and heres what i found
for the rear
18x8.5 4x100 35
for the fronts
17x7 4x100 40
makes sense or is this too wild?
the only reason the rears are bigger is... shit ionno i figured it would look sickLast edited by e30slut; 07-26-2009, 07:16 PM.
Originally posted by The Fast One! View PostI don't have coilovers but I do have bilstein sports with H&R race springs. so it is a low set-up. If you think I might need spacers, do you have any recomendations on some good but not too overlypriced wheel studs?
Originally posted by JuanPabloBongto View PostToo tall to fit?
inner wall will rub? or tread surface?
If so, what is the tallest tire (195 or 205 in width) that *will* fit the IX ?
E30s don't like tires much taller than the stock 24", as they were in reality only designed to hold ~23.2" tires in the first place (early E30s ran 195/60/14).
I don't make a habit of recommending anything larger than the stock diameter.
My question is:
Thank you.
Originally posted by drifty340i View Post
