This is a sticky topic.
  • ThaiRacer
    • 799
    #2596
    And why cant honda 4x100 steelies fit my e30?
    • Danny
      • 14216
      #2597
      17x9 et 20 = what tire size?
      • onaquest
        • Nov 2005
        • 805
        #2598
        Originally posted by ryno;
        what is the optimal tire size for 16x8.5?
        suspension is billy sports & H&R race on a 1990 325
        Originally posted by Mystikal
        Optimal tire would be a 245, but you're not fitting that on an E30 without a lot of work. I'd also need to know the offset of the wheels.
        forgot to mention et6
        http://bbswheels.blogspot.com
        • Mfever
          • May 2007
          • 1058
          #2599
          Wheel specs: 17X8 ET 22
          Compomotive TH
          Would I be able to fit these on a car with H&R race and billy sports without rolling fenders?
          • ejnight
            • Apr 2007
            • 3488
            #2600
            could you make a -10 off set work in the rear and what tire? Yes I have a fender roller.
            http://raceskids.com/
            • stinkydriverx
              • Jan 2008
              • 501
              #2601
              yoooo jay.
              just wanted to thank you for your help.
              The fronts (235/40/17) made it so i had to raise the front of the car up alot, probably an inch and a half. But i dont care about being low. I think it looks great!
              I told you i would show some pics when it was done!
              so heres the link tothe showroom thread
              Turbo m30 drift car build.
              500whp or bust.
              http://www.r3vlimited.com/board/showthread.php?t=256525
              • Mystikal
                Wheel Fitment Expert
                • 9602
                #2602
                Originally posted by ukrbmw
                Ok. I tried to read the whole thread, but 173 pages just overwhelmed me.
                So, question. I have an 87 325IS with rolled fenders to accommodate wide wheels/tires. I'm trying to stuff the widest thing possible under it - 245s preferably (this is a track car only). What is my best option for wheels? These are Hoosiers going on them. Previous owner ran 16X9s, but I forgot to ask make, offset, etc. Now I'm not sure which ones to get.
                Thanks.
                If you hug the strut with a 16x9, then yeah 245/45/16 is possible with a lot of fender massaging. Think ET10 front or so, ET15 rear.
                • Mystikal
                  • 9602
                  #2603
                  Originally posted by evo3
                  16x8.5 et of about +6. This is all around. I don't think there's much choice other than a 205 front, unless you want mad ugly square shouldered poke.
                  That's a very aggressive offset. 205/45/16 all around would be my bet.
                  • Mystikal
                    • 9602
                    #2604
                    Originally posted by rcfanatic
                    I have Enkei Zuko's that I just purchased, 16x7 and ET40. I'm trying to decide on whether to get 15mm spacers front and 20mm in the rear, or 20mm all around. With the 15's up front, it's a tad cheaper and might look better. 20's all around keeps with the stock track of the front and rear. Opinions? In the big scheme of things it's only 1cm difference. Has anybody noticed any sort of difference in handling, having driven both setups?
                    Thanks,
                    Adam
                    There will be no discernible difference, trust me. Go for the staggered, it does look better.
                    • Mystikal
                      • 9602
                      #2605
                      Originally posted by jaye30
                      what would be the best setup if i pick up a set of ronal ls sz 15 x 7.5 ET25
                      im currently running 15x7 alpinas with 3mm spacers up front 205/50/15 on the tires. i want more tire
                      225/50/15 is perfect for those wheels.
                      • Mystikal
                        • 9602
                        #2606
                        Originally posted by driftabryan
                        is there a way to make a 5 lug into 4 lug?
                        What.
                        • Mystikal
                          • 9602
                          #2607
                          Originally posted by ThaiRacer
                          How about 17x9 +20 will it rub? There falken Hanabi's n im thinking about getting a set. Will i have to worry about the Hub diameter? Also how does 215/40/17 in the fronts n 205/40/17 in the back with a 10mm spacer. Are what would u recommend for tire size?
                          You'll need spacers on the front to clear the struts. 5mm is enough.
                          I'd probably go 205/40/17 all around.
                          • Mystikal
                            • 9602
                            #2608
                            Originally posted by E30Beast2B
                            I was thinking of getting some 16x8 offset 20 with some 225/45/16 BFG Geforce KDW on a 87 325is lowerd on bilstein sports and H&R race springs. Will i have any issues? or should it fit?
                            You should be okay with the 87 quarters. Love those tires.
                            • Mystikal
                              • 9602
                              #2609
                              All around, see 2 posts up.
                              Just the rear, 215/40/17 with fender rolling and no spacers.
                              • Mystikal
                                • 9602
                                #2610
                                56.1mm centerbore vs. 57.1mm centerbore. Honda ones are the smaller of the two. VW ones will mostly work.
