This is a sticky topic.
Hey guys.
Just wanting to say Big Thanks to Mystical for help and advise on wheel fitment.
As promised, long overdue pics of my setup. I'm very happy with it in terms of handling. Yes, I admit it could sit a bit lower. I'll try to organize 1" - 1.5" shorter springs. from outside it doesnt look like much, and that was exactly the idea. But from behind you see two meaty tyres... that smoke once turbo comes on boost.
Rear: 16x7.5 et35, 15mm bolt on spacer, T1R 225/45/16. Probably 245 wide would fit, not sure if they make some in that size 245/45/16? Otherwise will go for 225/50/16 next time. No clearance issues on the back. No fender rolling. [edit]This is pre-FL coupe chasis.
Front: 16x7.5 et 35, 20mm bolt on spacer (required to clear custom 'solid' calipers) , T1R 225/45/16. I passed technical inspection, but it was noted they are borderline in terms of sticking out of the fenders. No rubbing at full lock. I dont think 225/50/16 tyre would fit... I would have to try it on... MMMMAAAYYYBBBBEEE.
Thanks again guys.Comment
15x6 et33, will these fit standard (non ix) e30 w/o rubbing or will they need spacers to clear front calipers?
Thanks!Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
LOL. I found, and bought, one of my two favorite wheels ever in a spec I never knew existed. Im pulling NO punches now, it must be done.
I greatly appreciate all your time and help though. If you're ever in Chicago, or I make it back up to TO, I owe you a drink, Sir.Comment
just ordered esm 001 16x8 0 offset. running a 90 325is with bilstein sport shocks and bavarian auto springs. what size tires should i use? i want as big as possible without mods or rubbing.Comment
