This is a sticky topic.
  • crazy seaman
    • Jun 2008
    • 52
    #2791
    im looking to get a set of these for my car. I currently have the tokico kit on my car which lowered it id say about 2 inches. Can anyone post a pic of these if they have them on there car- or give any input on the quality of these wheels.
    Im also up for suggestions if i should get the black ones with chrome lip (similar to my current wheels) or the all silver ones.
    thanks guys.
    this is a link to the wheels.
    • Mr Two
      • Jul 2008
      • 590
      #2792
      I want to run 17's, with ideally 245's non staggered. Right now I'm on 15x8 et 20 Slips, running a 225/50. ~3 degrees of negative camber in the rear, ~4 in the front, each side. Fender lips are rolled flat. It looks like I'd have enough space if I went with a lower offset - et5 or so?
      • Mystikal
        Wheel Fitment Expert
        • 9602
        #2793
        Originally posted by NickL
        17x7 et27 lowered on Ie3.
        Looking for the ideal tire size so no rolling will be needed. Thanks.
        Nice offset. 215/40/17, nothing needed.
        • Mystikal
          • 9602
          #2794
          thanks guys.
          https://wagen-wheels.com/products/Ky...e_17-96-4.html
          They aren't bad looking at all, but you'd need at least 20mm spacers to pull them off.
          • Mystikal
            • 9602
            #2795
            Everything you said made sense until the last sentence.
            245/35/17 all around is easy with your setup, but you'd want the offset around 15-20 (for a 17x8.5).
            • Mr Two
              • Jul 2008
              • 590
              #2796
              A lower offset would move the wheel outwards, correct?
              Right now I've got strut clearance issues in the front, so wouldn't I want a lower offset?
              • Mystikal
                • 9602
                #2797
                Strut clearance increases with wheel diameter (the strut is tilted slightly). 17x8.5 +18 would easily clear with a 245.
                • Mr Two
                  • Jul 2008
                  • 590
                  #2798
                  Aha. So, assuming 20mm for the adapters, I'd be looking for a wheel with an offset around 30-40mm, correct?
                  • Omaliyo
                    • 243
                    #2799
                    So im thinking of these, i have a early model e30 so = huge arches..... what would take to make these hella flush approved (im on gc's and bilie sport so hight can vary)... specs
                    16x8
                    et 34
                    front et = 5mm
                    rear et = 0mm
                    any help would be sweet!
                    Slamburglars Handbook:
                    5. Slamburglars don't get stuck on speed bumps, speed bumps get stuck on Slamburglars
                    • that1kidtony
                      • Sep 2009
                      • 130
                      #2800
                      any suggestions for wheel size with negative offset for e30 m50 im thinkin like 16x8.5 front 16x9 rear. but idk offsets well i want like 3 to 4 in of dish almost vip
                      • daniel
                        • 6703
                        #2801
                        negative offset? have fun with that
                        http://instagram.com/dslovn.drives
                        • z31maniac
                          • 17566
                          #2802
                          Originally posted by Mystikal
                          This is fitment #37 I've spec'd for you. lol.
                          Time for number #38.
                          16x9 215/40
                          16x9.5 225/40
                          Again, late model car with coilovers. What offsets for a flush fit, fenders will be heavily rolled.
                          www.gutenparts.com
                          • baaaaaaa
                            • 142
                            #2803
                            How would I fit a set of BBS RX 16X7's and where is the best place to buy the lugs and spacers.
                            • JGood
                              • Jan 2004
                              • 7959
                              #2804
                              15x7 et27 Kosei K1's
                              Can I fit 225/50 Hoosiers? What about 225/50 street tires? I don't mind rolling the fenders, just trying to avoid spacers. I need to figure out if I am using these wheels for street or track tires. If I can fit 225's, they will be my track wheels. If I can only do a 205, they will be my street/wet track wheels.
                              EDIT: While I'm at it, 16x8 et20 Rota Slipstream
                              Currently running 205/50/16 Hankook z214 R-comps. Can I run a 225/45 r-comp? Street tire?
                              e30 restoration and V8 swap
                              24 Hours of Lemons e30 build
                              • NickL
                                • 562
                                #2805
                                Thanks a lot man.
                                1987 325is - S52
