This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #3076
    Originally posted by Lofty
    Thanks. What'd be the lowest offset for 7x15 with 225 50 15? I can roll the fenders but want to avoid more agressive work.
    Also as a matter of interest, which is worse for low offsets, front or rear?
    Even with a flat roll, +20 and that meaty tire can rub on an 88+. Anything higher than that should be okay.
    The front of an E30 actually has far more clearance than the rear, regardless of year.
    • Mystikal
      • 9602
      #3077
      Originally posted by stevetrocs
      I am running stock size 205/55. I am getting custom made spacers from the group buy section on this size so I can get any sizes. Would something other than 15/20 be better? I know that those are the stock size spacers from h&r. I found one vert running 16/20 with bigger tires than mine.
      So since I can get any size spacers should I stick with 15/20 or get a custom size??
      Thank you for all your help.
      If you're willing to stick to 205/55, my brain calc says 18/23 is good. That's truly the limit for unrolled fenders though, you will clear the rear by literally 2-3mm.
      I say stay with 15/20, honestly.
      • Mystikal
        • 9602
        #3078
        Originally posted by wildstoats
        Long time reader, first time advice seeker! :p
        I am currently looking at two sets of wheels. Here are the specs:
        Set 1:
        16x8 - Offset: +3
        Set 2:
        16x8 - Offset: +9
        Late body style car / Lowered on Ground Controls
        What size tires do you think would work well and how much massaging / cramming do you think it would take? I'm not worried about pulling / rolling but would like to avoid cutting if possible. I read through some of your other recommendation and it seems like 16x8 +0 is not worth it so I may have answered my own question but I was curious as to whether 3/9mm would make any appreciable difference.
        Thanks in advance!
        -Brian
        It definitely makes a difference. The +9 setup would fit very nicely with 205/45 tires, and you may not even need to roll anything. The +3 will fit with a flat roll in the back.
        If you don't have camber plates the +3 will be sticking outside of the front fenders slightly. If you can deal with that (it won't rub), then you're fine.
        • catal77
          • Aug 2009
          • 34
          #3079
          hello will e32 style 5s fit without a spacer? thanks in advance
          • Mystikal
            • 9602
            #3080
            Well they are 5x120, so that's one obstacle. What car are they going on?
            • catal77
              • Aug 2009
              • 34
              #3081
              on an 89 325i. I am planning a fill and drill
              • Mystikal
                • 9602
                #3082
                Well they're 15x7 +20 and clear the big calipers on the 7, so they should be fine without spacers. I've never seen someone try it, but I don't foresee any issues.
                • bmw325csi
                  • May 2007
                  • 4045
                  #3083
                  Jay,
                  just picked up some esm 002 wheels
                  rear-16x9 et20
                  front- 16x7.5 et20
                  watta ya think about 215/40 rears with 205/40 fronts? I want the meatiest tires I can have on there but the tire shop swears anything bigger will rub.
                  BTW car is 88 vert on billie sports/eibach (almost no gaps)
                  harry/harout
                  • MvancE30
                    • 138
                    #3084
                    ok from reading through this thread i think i figured out the answer to my question.
                    I was wondering what would be the widest possible tires for stock e30 without spacers.
                    I have a 91 and wanna run some wide tires in the future. With 15 inch rims then 225's might be cutting it close? and with 16 inch rims i should be fine? Im planning on getting some bilsteins(sp?) with H&R's so im not sure if that makes a difference.
                    sorry for the n00b question but never really saw that discussed anywhere else.
                    • OldsCool
                      • Jan 2009
                      • 157
                      #3085
                      i got wheels in 16x7j with et25 what tire size should i use? i would like to use some 225/45 R16 since the upcoming m50 swap will need a little grip. will that setup work and is there any modification needed?
                      edit: my car is lowered something like 80mm(~3") in the front and 30-40mm(1-1.5") in the back
                      • Matt Arruda
                        • Nov 2008
                        • 80
                        #3086
                        Originally posted by Mystikal
                        That equates to +25, which is about perfect for a 15x8 on the rear. Should be close to dead centered between the trailing arm and bodywork.
                        I forgot to mention this was on a E30 will this still work ?
                        • Flyingbricke30
                          • Apr 2009
                          • 46
                          #3087
                          Hi, I'm looking at a new set of 16x7 4x100 MBMotoring Mesh X Wheels from Discount Tire. Car has Eibach pro spring kit lowers car about 1.5" F+R
                          Offset is 38.
                          a] Can these fit with a spacer? what thickness?
                          b] what tire size would work?
                          Thanks!
                          • Flyingbricke30
                            • Apr 2009
                            • 46
                            #3088
                            Offset is 38.
                            Thanks!
                            Yes, sorry I too forgot to mention model..E30 :???:
                            • 88SuperETABD
                              • Apr 2009
                              • 911
                              #3089
                              So I have the BBS RX's? I think thats what they are. They are 16x7J. ET 35...thats what it says on the rim. Also...I have 205/50/16's on em now...was wondering if thats the best tire size for that rim. heres a pic if it helps. Also...whats the 91w mean?
                              p.s. Have 10mm spacers on all wheels. if that matters.
                              (SOLD) 1988 327i Build Thread: http://www.r3vlimited.com/board/showthread.php?t=155086
                              1970 Gruppe 2 2902 M20 Turbo Build: http://www.r3vlimited.com/board/showthread.php?t=373891
                              • brandonj1
                                • 318
                                #3090
                                these wont fit on an e30 will they, they are 18x7.5. but they are really inexpensive for rays and they arent chrome they are silver they pic is really bad
