This is a sticky topic.
  • OldsCool
    • Jan 2009
    • 157
    #3106
    Originally posted by Mystikal
    Will be 100% fine. No rolling needed.
    thanks!
    • rpm620
      • 204
      #3107
      Looking at a set of 16x8 ET20 wheels .. would like to run the widest tire i can all the way around. Car is on Intrex springs from the PO i have not switched them yet.. and i dont know the drop but i know its low, because the front fender almost tucks the tire..
      what size tires can i run. and i dont mind rolling/pulling the fenders a bit.
      E30 Turbo 2.8L - 60ft - 1.70 :: 1/8th - 6.99 :: MPH - 105.47 :: 1/4 - 10.66 :: MPH - 132.53
      *RIP* E36 M3 - 60ft - 1.944 :: 1/8th - 8.64 :: MPH - 80.00 :: 1/4 - 13.55 :: MPH - 99.95
      • Fusion
        • Nov 2009
        • 3658
        #3108
        17x8.5" all around Keskin KT1 offset 15
        What tires will I need? I'm not affraid about the rear but the front looks like it might need stretch.
        This could be the same, cept rear is 17x10"
        • vpracer325
          • 109
          #3109
          hi i have an 87 325is with a zender widebody kit , i had 15x8.5 zender sports with a -6 offset, the wheels im thinking of buying are 15.8 with a 16 offset what size spacers would be needed to make them fit the same.
          • vpracer325
            • 109
            #3110
            nobody?
            • Erik
              • Oct 2005
              • 5370
              #3111
              Originally posted by vpracer325
              nobody?
              Patience, Jay works in Mystikal ways, he will get to your question when he is ready. Wheel sizing and offset are srs bznz.
              Just because you're impatient, 30mm. :p
              -Erik
              Originally posted by 87e30
              • Mystikal
                Wheel Fitment Expert
                • 9602
                #3112
                Originally posted by CR325IS
                how about a 225/50/16?
                Nope.
                • Mystikal
                  • 9602
                  #3113
                  If you go absolutely insane with a fender roller and pull the guards out, a 245/45/16 fits.
                  If you want a less extreme project, 225/45/16 works with just a flat fender roll.
                  • Mystikal
                    • 9602
                    #3114
                    Heh, those are definitely 17x10. Good friend of mine's car (with another good friend's wheels on it). Ironically that M30 beast just sold a few weeks ago.
                    Anyways, that's an aggressive fit. The car in the pic has the +20 version, and as you can see it's already pretty flush. You'd have to run 205/40/17 all around on those wheels, with flat fender rolls.
                    • Mystikal
                      • 9602
                      #3115
                      What he said!
                      • Matt Arruda
                        • Nov 2008
                        • 80
                        #3116
                        Please help me build a set of wheels to mount slicks on!
                        Here is the link to the site I will be ordering them from with a spec sheet. I want to buy these but dont want to screw this up because they are made to order and they offer no refunds if they dont fit.
                        I recently swaped to a 5 lug Z3 rear, so my requirements are 5 lug obvious, and rim diaameter of 15" no exceptions. Please help me with back space brake caliper clearance ect.
                        http://www.cwibeadlock.com/SpeedSeriesOrderForm.pdf
                        • jflower
                          • 262
                          #3117
                          Hey Jay...
                          Not sure if you remember me or the project, but here's what I got...
                          Late body E30 with massaged rear fenders. I wouldn't say rolled completely flat, but definitely rolled. E30 M3 suspension with Fr500lb/Rr400lb springs. Front fenders are not rolled, and I want to run fender liners. What are the chances of 17x8 et20 throwing stars fitting with a 215/40 (all 4 corners) considering I'm pretty sure you need to use 5mm spacers to clear the calipers?
                          cheers
                          jflower
                          king of bad decisions.
                          • Mystikal
                            • 9602
                            #3118
                            Slicks meaning for drag?
                            • Mystikal
                              • 9602
                              #3119
                              Originally posted by jflower
                              Hey Jay...
                              cheers
                              jflower
                              You'll have more than enough space, even with the spacers installed.
                              • Fusion
                                • Nov 2009
                                • 3658
                                #3120
                                Mystikal: a big thank you to you, sir!
