This is a sticky topic.
    Originally posted by blefevre View Post
    I can't find a definitive answer to this.
    I have 14in. basket weaves with 205 wide tires - BFG Traction T/A.
    Can I fit 15mm H&R spacers in the REAR without rubbing? I will be lowering the car on H&R sports very soon, will it rub then?
    Yup, no problem. I believe the magic numbers I spec'd a while back for stock weaves was 15mm front and 20mm rear spacing would be okay, with 195 tires. You'll be fine with 15mm and 205s.
      Originally posted by BustaRhymes325i View Post
      Ok crazy fitiment question here:
      I have 2 Merc Benz AMG wheels, size 18x9, ET23, 5x112. If I use a 4x100 to 5x112 adapter (dangerous, I know) which is 20mm thick, will these wheels fit on the rear?
      I am dropped on Eibach sports and Bilsteins. If so, what type of tire sizes am I looking at? Car is a 1989 if that helps.
      Thanx!
      It'll be extremely tough.
      I have the exact same dilemma right now, as I'm contemplating putting my 18x9 +22 5x120 BBS' from my E36 onto my E30 with 18-20mm adapters. Because of the sheer height of the wheel, there is very little room left to gain space from tire stretching. By this I mean a 16x9 +3 wheel can easily fit with a fender roll and 205/45 tires, but once you add 2" more wheel...it gets TOUGH.
      I wouldn't try it, unless you're willing to either a) invest in flaring or b) give up without being mad.
        Originally posted by maniacmatt View Post
        Okay I have one. The car is a 90 325is with GC coils, front camber/casterplates and IE weld in rear camber toe kit. Fenders and quarters are not rolled.
        The wheels I want to fit are:
        Front
        7.5x16 et27 I currently run a 3mm spacer to clear my Massive street kit, not sure if I would need it with these wheels.
        Rear
        9x16 et21
        What tire sizes am I looking at running to make these fit? Will I need spacers front or rear?
        The front can easily handle 225/45s without any modification, however, the rear will be much more difficult. Your maximum there would be 215/45/16, so you may want to just use that size all around.
        If you're willing to crank up the rear camber (read: more negative than stock) you could do the 225/45 all around though.
          Originally posted by e30bri View Post
          Fitment Question:
          88 325is IE st3 springs
          15x8 et20
          Tire Hankook rs3 225/45/15
          THANKS!!!
          Perfect.
            Originally posted by akorcovelos View Post
            little update, I ended up having to go with 215/40/16 up front, which happens to be exact same OD as the 245/35s in back. Only problems will be more drastic stagger and stretching 215s on an 8.5" wheel.
            I'm still looking for a better fitment option for my next set of tires if anyone has any suggestions.
            I didn't ignore your other q's, just noticed this as I was replying to the first and decided to just reply here.
            Keeping the OD's the same was a smart move. For your next setup I'd just run 225/45/16 all around.
              Originally posted by stegosaurus View Post
              I have some Kopi Alpina reps 17x7.5 ET20 which are stretching 215/40/R17 tires. I bought them needing new tires, I'm hoping I can do 225/40/R17 because I really don't like stretch.
              No fender pulls or rolls, car is a little lower than usual, but not much. Doesn't rub anything as is. Might have some clearance issues in the front I'm guessing with that plastic shroud, but I could just take it off.
              If bigger tires won't happen without rolls, pulls, spacers, then I guess I'll stick with the 215s.
              What do you guys think?
              You're at the maximum for that wheel without fender modification.
              A nice broad 215/40 should remove any stretch. Look for wider section widths of perhaps 8.7"+.
                15x8 ET 20, 225/50
                Late model, I'm asking for a serious roll/pull aren't I?
                Car is on coilovers. 318is.
                www.gutenparts.com
                  Yay Jay is back <3
                  16x7 Alpinas, I think they're et28, they might be different though.
                  225/45/16? Any rolling, etc? Dropped on races.
                    Originally posted by Mystikal View Post
                    Originally posted by E30SPDFRK View Post
                    16x10 in the back, whats the highest offset I can run before I hit the trailing arm/spring perch?
                    +13 is safe.
                    I want them to be as flush as possible. I did some measuring when you were gone and I think et18 is going to just clear. Worst case scenerio I'll just trim the trailing arm a little. ;)
                    Byron
                    Leichtbau
                      Really? Damn I would have thought that with that offset 225's would be be easy in the rear. How much camber are we talking about? Would rolling the rear fender lips help.
                      I was hoping for at least a 225 in the rear, 215's on a 9'' rim will have a fair bit of stretch will they not?
                        Could I get away with a 215/45 or is 215/40 my best bet? 215/45 is just over 10mm larger sidewall than 215/40, too much?
                          Mystikal you rock!!! Thanks for the help.
                            Originally posted by z31maniac View Post
                            15x8 ET 20, 225/50
                            Oh yeah, serious roll. Earlier cars can pull it off, but that's a massive section width for a late model to take in.
                              Originally posted by Danny View Post
                              Yay Jay is back <3
                              <3
                              225/45 would fit perfect, no rolling.
                                Yup, I'd say you're on the mark. I usually leave a few mm to be safe in my quotes, just to make up for tires with large curb protectors and the like
