oh and i have another question safe to run adapters for porsche d90s, i assume fk is a legit brand to go?
This is a sticky topic.
ESM 002
16x7.5
Offset 20
Car: 88 325 E30
Brakes: Stock
Springs: Eibach Pro Front Drop 1.6", Rear 1.4"
I assume that the wheels fit w/o spacers looking at the esm website - What tire size do you recommend?? Thanks!Comment
Jay,
just picked up some esm 002 wheels
rear-16x9 et20
front- 16x7.5 et20
watta ya think about 215/40 rears with 205/40 fronts? I want the meatiest tires I can have on there but the tire shop swears anything bigger will rub.
BTW car is 88 vert on billie sports/eibach (almost no gaps)
For the front the sky is the limit, run the same size as the rear if you'd like to. Please don't use 205/40, it's tiny and will look ridiculous.Comment
ok from reading through this thread i think i figured out the answer to my question.
I was wondering what would be the widest possible tires for stock e30 without spacers.
I have a 91 and wanna run some wide tires in the future. With 15 inch rims then 225's might be cutting it close? and with 16 inch rims i should be fine? Im planning on getting some bilsteins(sp?) with H&R's so im not sure if that makes a difference.
sorry for the n00b question but never really saw that discussed anywhere else.
As for diameter, even 19s are easy.Comment
i got wheels in 16x7j with et25 what tire size should i use? i would like to use some 225/45 R16 since the upcoming m50 swap will need a little grip. will that setup work and is there any modification needed?
edit: my car is lowered something like 80mm(~3") in the front and 30-40mm(1-1.5") in the backComment
15mm spacers all around, or a 15/20mm F/R stagger for a more even stance. 205/50/16 would be the typical size, but you can go up to 225/45/16.Comment
So I have the BBS RX's? I think thats what they are. They are 16x7J. ET 35...thats what it says on the rim. Also...I have 205/50/16's on em now...was wondering if thats the best tire size for that rim. heres a pic if it helps. Also...whats the 91w mean?
p.s. Have 10mm spacers on all wheels. if that matters.
You can run up to 225/45/16 on them. 215/45 or 205/50 work fine too. 91 is the load rating, W is the speed rating (both for the tire).Comment
these wont fit on an e30 will they, they are 18x7.5. but they are really inexpensive for rays and they arent chrome they are silver they pic is really bad
http://portland.craigslist.org/clk/pts/1635012388.htmlComment
Sorry, it was suggested that I try another wheel instead:
ESM 002
16x7.5
Offset 20
Car: 88 325 E30
Brakes: Stock
