This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #3511
    Originally posted by mega_ls1
    18x8½in with 225 35 18. what offset? No spacers, will be rolling and pulling fenders to fit, thanks!
    +20 will leave plenty of room. You can even creep it up to +23 safely if you really want to hug the inside and gain clearance.
    At either offset you won't need to do very extreme fender work, a flat roll should be enough.
    • zaklikestuna
      • Jun 2010
      • 1
      #3512
      Anyone running a 17x8 et0?
      I'd like to do style 5s with a 4x100 to 5x120 20mm adapter. This would turn the style 5s from et20 to et0 correct?
      Then run a 215/40 or 205/40?
      let me know what you guys think.
      • Mystikal
        • 9602
        #3513
        205/40, with pulled fenders. You'll also want a 5mm spacer on the back just to even out the fitment, as the front will be poking. I still don't recommend such an offset, but if you want to go for it that's the way.
        • fiftytakedowns
          • 2460
          #3514
          HEy MYstikal, Some serious advice needed here:
          I got two cars:
          the E30:
          and the 2002:
          Should I go lower in the 02 For perfect stance, What spacers should I run on either car to get some legit/ perfect fitments. Also for the 2002 I have some 15in euroweaves. wondering what tire you recommend( its also turbocharged). I love the look of slammed cars, with perfect fitment. Wondering if I should go coilovers for the 2002 as well. maybe even trade wheels with either car?
          the konig rememberers are on 195 50 16 I think and are et24
          Let me know what you think,
          Thanks
          [/url]
          Team USA Wrestling 67KG
          • ak-
            • 12422
            #3515
            16x8.
            et23.
            tires going to be 205/45.
            My car is slammed and staying that way.
            I have camber plates.
            Need to fill up my fenders though.
            They are/will be rolled(no flare!).
            Space specs?
            Thanks!
            1991 325iS turbo
            • theox69
              • May 2008
              • 1732
              #3516
              16x9 et12 all around.
              Tires are 215/45/16 Direzza DZ101's.
              How much fender work do I need in the front or back -- the car's on coilovers.
              you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
              • livetheride
                • 444
                #3517
                I have borbet type b's in 15x7 et35. Will these fit a 325i/e without spacers?
                • Mystikal
                  • 9602
                  #3518
                  I got two cars:
                  the E30:
                  Thanks
                  I know next to nothing about 2002 fitment.
                  The Konigs should be +20. I say buy proper sized tires (up to 225/45) and just enjoy it as is. If you really want spacers, you can fit a 10mm in the back with those tires with plenty of space left.
                  • Mystikal
                    • 9602
                    #3519
                    Originally posted by ak-
                    16x8.
                    et23.
                    Space specs?
                    Thanks!
                    Redrilled or 5 lug weaves?
                    10mm in the rear is about enough. Front completely depends on the camber, if you dial it way up you could do 15mm+, but that wouldn't be too smart.
                    • Mystikal
                      • 9602
                      #3520
                      Roll the rear fenders completely flat and see if that's enough. Depending on spring rate and ride height you may need a slight pull on the rear.
                      • Mystikal
                        • 9602
                        #3521
                        Nope, those are the VW version. You'll want 15mm spacers.
                        • ak-
                          • 12422
                          #3522
                          Oh crap I'm sorry.
                          They are drilled 4x100 so the offset is still et23 standard.
                          Same specs as you gave me?
                          1991 325iS turbo
                          • Roy325iX
                            • Jul 2010
                            • 7
                            #3523
                            Friendly Hello to everyone and big thanks to Mystikal for so much great info on wheel fitments. I'm a new guy here and recently picked up an '88 325iX. I would like to use either 16x7 et20 or 16x7.5 et 20 5 bolt wheels on my iX. I will be using 18mm adapters to install the wheels (effectively giving me et2) and 205/55/16 tires. Will this all work on my iX? Thanks!
                            • brianpgriset
                              • 138
                              #3524
                              I just got my ESM002's 16x7.5 et 20. Lowered ~1.6 inches on FK's with rolled fenders. I was set on 205/50/16 G-force sports but now I'm thinking 205/45/16 might be better. Should I stick with the 50's? Any comments on the tires? I wanted to be able to get them at Tire Discounter, these will be daily driver ish tires and for play on streets, not track tires. I just want something with decent treadwear, balance and ~$100/tire. Seemed people on here are OK with them.
                              Thanks.
                              • unloadedak
                                • 1197
                                #3525
                                Originally Posted by unloadedak
                                doing a 5 lug e36 m3 swap with z3 rear. found these wheels super cheap locally forsale with decent tires.
                                Racing dynamics RGR 17x8 5x120 ET38 with 245/45/17 tires. tire size calculator is saying its 1.7" too big and from what i've read on here that is way too much.
                                i'll most likely not be lowered as i'll use the stock e36m3 springs.
                                thanks
                                adam
                                Wheels work, tires are not even close. 215/40 or 235/40 are good to go.
                                haven't visited for awhile. just picked up some 17x8 et20 style 5s with 215/45/17s on them.. will i be able to run these tires for awhile? i'm going to be riding on stock e36 m3 springs so it shouldn't really be lowered at all.. eventually wanting to go coilovers with 235/40
                                2003.5 Imolarot M3: daily
                                1995 Alpinweiß M3: hpde
