This is a sticky topic.
  • theox69
    • May 2008
    • 1732
    #3526
    Originally posted by theox69
    16x9 et12 all around.
    Tires are 215/45/16 Direzza DZ101's.
    How much fender work do I need in the front or back -- the car's on coilovers.
    Originally posted by Mystikal
    Roll the rear fenders completely flat and see if that's enough. Depending on spring rate and ride height you may need a slight pull on the rear.
    Would a 215/40 make much of a difference over a 215/45?
    you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
    • IRON-E
      • 16548
      #3527
      I got a set of 16X7.5 wheels, et 20 with a nice 1.5-2" lip I'm dropped on Billys and H&R sports springs but the fronts have RichardKeith 15mm drop hats. I have lightly rolled my rear fenders in the rear but not the fronts since clearance isn't an issue, what do you recommend for a tire size as my DD.
      @IRON-E30 aka Edwin:D
      • khnordeen
        • Oct 2007
        • 459
        #3528
        I planning on running an 8mm spacer in the rear on my 15x7 et20 Type A's and was wondering if I would need extended lugs to be able to run that spacer.
        I just got flat caps for my Type A's today and just want to know if I would have any issues using them with extended lugs. Thanks
        -Kyle
        • Dude
          • 1119
          #3529
          I gots a question. With stock bottle caps and tires on a car dropped about 2.5", how wide spacers can you use without issues?
          Also a tad off topic, would it make a huge difference switching to to a bigger wider wheels with a lower profile tire? Obviously that looks better but if theres not a huge difference ill stick with bottle caps.
          Thanks
          • MC Hammered
            • Jul 2008
            • 2076
            #3530
            I STFA but would still like a confirmation about this setup.
            With a 225/45/16 on a 16x9 ET15 square setup fit without any issues?
            I have GC coilovers and camber plates.
            My 1989 e30 s52 Touring... this is Betty
            My 1989 325i vert (sold)...this is Nina
            My 1991 M5 (sold)... this is Veronica
            Photo comparison: OEM vs aftermarket windscreen for a convertible
            • Apps
              • 175
              #3531
              Jay,
              I've got a set of euroweaves and looking at Ziex 912 225/50/15...I'd like a flush look without any rolling if possible. Camber is at approx. 2.5 in the rear and maybe -.3 in the front, bilstein sports, and H&R sport...do I need spacers front or rear? If so what sizes?
              • TheRooster
                • Jan 2010
                • 168
                #3532
                i was looking at the ESM-002r. I have hr race springs and bilsteins on my car now. I want to run 17x8.5(15 offset) in the front and run 17x10(20 offset in the rear). what kind of spacers will i need and tire sizes? I know i will need to roll my fenders
                • Roy325iX
                  • Jul 2010
                  • 7
                  #3533
                  Does Jay no longer take questions? Totally understandable after so many years of the same questions asked over and over!
                  • Mystikal
                    Wheel Fitment Expert
                    • 9602
                    #3534
                    Sorry guys, it was my bday on the 17th and I took a small vacay from here. Back to work!
                    • Mystikal
                      • 9602
                      #3535
                      Originally posted by ak-
                      Oh crap I'm sorry.
                      They are drilled 4x100 so the offset is still et23 standard.
                      Same specs as you gave me?
                      Yeah, same specs are good. The M3 hubs are pushed out a bit, but what I said was the safe route for 4-lugging.
                      • Mystikal
                        • 9602
                        #3536
                        Originally posted by Roy325iX
                        Friendly Hello to everyone and big thanks to Mystikal for so much great info on wheel fitments. I'm a new guy here and recently picked up an '88 325iX. I would like to use either 16x7 et20 or 16x7.5 et 20 5 bolt wheels on my iX. I will be using 18mm adapters to install the wheels (effectively giving me et2) and 205/55/16 tires. Will this all work on my iX? Thanks!
                        No! The offset is far too low and the tires are an inch too tall. You need an offset of 20 at the lowest and tires that are 24.4" or shorter.
                        • Mystikal
                          • 9602
                          #3537
                          Originally posted by brianpgriset
                          I just got my ESM002's 16x7.5 et 20. Lowered ~1.6 inches on FK's with rolled fenders. I was set on 205/50/16 G-force sports but now I'm thinking 205/45/16 might be better. Should I stick with the 50's? Any comments on the tires? I wanted to be able to get them at Tire Discounter, these will be daily driver ish tires and for play on streets, not track tires. I just want something with decent treadwear, balance and ~$100/tire. Seemed people on here are OK with them.
                          Thanks.
                          Stick with 205/50. 205/45 will make your ride height look worse (more gap) plus throw the speedo off more than it is.
                          • Mystikal
                            • 9602
                            #3538
                            Originally posted by unloadedak
                            haven't visited for awhile. just picked up some 17x8 et20 style 5s with 215/45/17s on them.. will i be able to run these tires for awhile? i'm going to be riding on stock e36 m3 springs so it shouldn't really be lowered at all.. eventually wanting to go coilovers with 235/40
                            Nope. With the E36 suspension those wheels will be poking outside of the fenders. 205/40 is about the biggest you want to go without drastic fender work.
                            • Mystikal
                              • 9602
                              #3539
                              Yep. Gives you a good amount of clearance with the shorter sidewall, you should be able to get away with just a flat roll.
                              • Mystikal
                                • 9602
                                #3540
                                Originally posted by iron-e
                                i got a set of 16x7.5 wheels, et 20 with a nice 1.5-2" lip i'm dropped on billys and h&r sports springs but the fronts have richardkeith 15mm drop hats. I have lightly rolled my rear fenders in the rear but not the fronts since clearance isn't an issue, what do you recommend for a tire size as my dd.
                                205/50/16.
