This is a sticky topic.
If you want flush you're looking at absolutely massive spacers, like 50mm rear 40mm front. Obviously that isn't optimal.Alright i need some help with ordering some custom spacers. My car has john cooper works r112 rims right now with an et 48. The previous owner put them on and it rubs the top of the front strut. Well im going to order some custom spacers with the right center bores and i was wondering what size spacers to run front and rear. The car will be lowered on gc's with shortned struts, and i would just like for the wheels to be flush with the fender. They are 17x7. This is on an early body car btw. Thanks for any advice
I'd go with something realistic like 20mm front 30mm rear. They won't be near flush at all, but is a good overall fitment.Comment
Even with the 205/55 you will not rub with 20mm spacers all around. That setup is only 3mm more aggressive than a stock 15" weave (i.e. no difference).Comment
Don't know if this question belongs here, but I'm guessing it does since it's related to fitment. I have 15x7 O.Z. Fittipaldi weaves with an et26 offset wrapped in 205/50/15 rubber. I wanted to put some spacers to have a more flush look without having to roll the fenders. If I put 10mm spacers, would that bring my wheels out enough? or should I look for some bigger spacers? Thanks.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by Wh33lhopVANOS: sometimes you just need to go full retard.Comment
guys, have a question, my e30's suspension set up is Billstei HD's+H&R races, i have a set of 16x8 et11 RS's, what would be the tire size advices?..i had Alpinas 16x7 et20 with 225/45/16...perfect fit. would the same work on my new RS's?...
thanks in advance1988 E30 M3
My eBay store: http://stores.ebay.com/UberpartComment
I just bought a set of maxxim lemans 16x7.5 et35. Yes, 35. The centerbore is larger too. Right now, they'll rub on my front struts. I'm thinking of running 10mm up front and 15 mm rear in terms of spacers. Can I simply get custom hubcentric spacers or do I need to buy the rings too?1989 325is / 2.7, 274 cam, e30 M3 5-lug
1989 LN106 Hilux / 3.0TD SFA
1974 2002tii / stock
2002 IS300 / 5spd LSDComment
Hey, first and formost, thanks for doing this for the community. Wish there was someone like you when i was buying wheels for my gti.
Anyways, pretty new to the E30 world and would like to know how these will fit..
F= 9x17et6
R= 10x17et19
I know it will be quite aggressive but the car will be on air, so not to worried about driving, just want to make sure it wont look like a 94 rodeo from south central.
Thanks,
MikeComment
I got 16x8 +20 rims and 225/40-16 tires. How big of a spacer will I need to make it more flush. I'm on H&R Race with Bilstein HD. I also have access to a fender roller. Thanks in advance!FeedbackInstagram - @e30_mtech2Comment
wow....250 pages of pure fitment hahahah this is awesome.
borbet b's 16x9 et 15 on all four corners with 215/40r16's
what kind of tires(if current ones are not adequate) do you recommend and what size spacers?
i am trying to go as wide as i can without pulling(fenders are rolled) and as low as possible ;)Last edited by charlescho; 10-18-2010, 07:26 AM.Comment
what does et25 or et15 or any et mean?
Patrick - IG:niicknac
RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, baggedComment
Going to be running 16x8 et20 all around, just wondering if i should run a 205/40 or a 205/45?
My car is really low now, tucking tire, however i have a B+G "lowering" suspension setup i will be putting on (which will raise the car up) and im on the fence if i should run a 205/45 to minimize wheel gap?
`92 325 vert - `90 325 coupe `99 m3 - Instagram @e30LComment
10mm in the rear alone would be a nice upgrade. Otherwise 10 front 15 rear!Don't know if this question belongs here, but I'm guessing it does since it's related to fitment. I have 15x7 O.Z. Fittipaldi weaves with an et26 offset wrapped in 205/50/15 rubber. I wanted to put some spacers to have a more flush look without having to roll the fenders. If I put 10mm spacers, would that bring my wheels out enough? or should I look for some bigger spacers? Thanks.Comment
Unfortunately no, the much more aggressive fitment of the new wheel means you'll have to run a slight stretch. 205/45 is my recommendation.Comment
