This is a sticky topic.
  • Adrian_Visser
    • Jun 2006
    • 2823
    #4111
    I'm running 16x7.5" CR-7 rims with an et30 offset, I want to run 225-50R16 Dunlop Direzza Starspecs, am I going to need 10 mm spacers up front?
    '89 Alpine S52 with goodies
    • bloodshot-e30
      • 1494
      #4112
      Originally posted by Mystikal
      Change the front to 205/50/16 to match the diameter of the rears. You'll be rolling the rear arches to a slight "pull" to get that setup to work.
      i couldnt get the tires i ordered in a 205/50/16 had to get 45's so hopefully it will work.
      ^Back in the game^
      BUILD THREAD: http://www.r3vlimited.com/board/showthread.php?t=201281
      FS thread:
      http://www.r3vlimited.com/board/showthread.php?t=214105
      • E30_(1st Musk)_
        • 2008
        #4113
        h&r race/bilstein sports with 15mm drop hats.
        15x8 et 20. 205/50/15
        whats the thickest spacer i can run with minimal fender rolling?
        • trackjunkie21
          • Jan 2010
          • 3962
          #4114
          Well I found a deal on a set of esm 009r's, 16x8/16x9 staggered setup et20 front and et15 rear. Tires in the front are 205/45/16 and the rear are 215/40/16. Will this look stupid on my car? I am lowered on H&R sports and was wondering if there would be too much gap. Thanks.
          Originally posted by Wh33lhop
          VANOS: sometimes you just need to go full retard.
          • bpmack16
            • 1521
            #4115
            I would like to know if a 16x7.5 front et20 will rub and or poke out? allso will the rears I have work 16x9 et15 any spacers needed on fronts or rears and suggested tire sizes front and rear. Thanks
            • Mystikal
              Wheel Fitment Expert
              • 9602
              #4116
              Tires are too tall. I know there are others who have successfully fitted them, but they will scrub the front inner fenders often.
              • Mystikal
                • 9602
                #4117
                It'll work, you'll just have uneven tire heights. No biggie if you're not OCD.
                • Mystikal
                  • 9602
                  #4118
                  10mm rear should even it out.
                  • Mystikal
                    • 9602
                    #4119
                    I think they'll look pretty good. Cut a coil on the front or use drop hats and it would look great.
                    • Mystikal
                      • 9602
                      #4120
                      The fronts will be fine, actually A LOT more sunken in than the rears. If you're running those together I'd suggest at least a 10mm front spacer to even them out. No spacers on the rear.
                      205/45 and 225/40 will work fine.
                      • bpmack16
                        • 1521
                        #4121
                        Is a 10mm spacer a lot and safe
                        • Adrian_Visser
                          • Jun 2006
                          • 2823
                          #4122
                          Hmm well I plan on doing quite a bit of auto-x and hopefully a couple HPDE's this summer so I want some decent tires. It seems that for 16's the widest you can get for an extreme performance summer tire is 225mm and always with a 50 percent aspect ratio.
                          I'm a noob to tire fitment. How much of a problem would the scrubbing be if I was doing auto-x? I mean I'd be using a lot of steering lock and what not.
                          I guess my other option is to run Kumho Ecsta XS's or Falken Azenis RT-615k's since they're available in 215 45 r16.
                          • Pussy30
                            • Feb 2011
                            • 463
                            #4123
                            Originally posted by Pussy30
                            Would be considered flush with rolled fenders on a 5 lug swapped e30 with 318ti rear and 325is fronts with m3 control arms and Offset CAB's?
                            Trying to see if I could possibly fit 17x8's et18 with a tad bit of poke.
                            Okay this same setup but I bought some 15x7 Enkie 92 reps. I had to choose offset 0 or 20. I knew 0 would poke and Im not planning on stretching tires becuase that would be dumb on 7 wide, so I got offset 20. As for tires Im thinking 205/50/15, ive run this size on 15x8's with a hair of stretch so this should look normal. I do have rolled fenders and theres a good chance im gonna wanna run spacers to get sortaflush, i was thinking 10's or 15's, thoughts?
                            • VinniE30
                              • 2113
                              #4124
                              Wheels are 7x15 ET35
                              Car is 1989 325i
                              Can I put 225 width tires on the back and 215 on the front?
                              What about sidewall? Should I get the smallest sidewall possible or the thickest?
                              How about 40 or 50 for the sidewall?
                              Car is just used as a daily driver for now.
                              Zinno '89 <24v swap in progress>
                              • Danny
                                • 14216
                                #4125
                                17x8 et25 with a 245/40/17 tire? Or do I have to run a 235/40/17?
