I'm running 16x7.5" CR-7 rims with an et30 offset, I want to run 225-50R16 Dunlop Direzza Starspecs, am I going to need 10 mm spacers up front?
This is a sticky topic.
^Back in the game^
BUILD THREAD: http://www.r3vlimited.com/board/showthread.php?t=201281
FS thread:
http://www.r3vlimited.com/board/showthread.php?t=214105Comment
h&r race/bilstein sports with 15mm drop hats.
15x8 et 20. 205/50/15
whats the thickest spacer i can run with minimal fender rolling?]Comment
Well I found a deal on a set of esm 009r's, 16x8/16x9 staggered setup et20 front and et15 rear. Tires in the front are 205/45/16 and the rear are 215/40/16. Will this look stupid on my car? I am lowered on H&R sports and was wondering if there would be too much gap. Thanks.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by Wh33lhopVANOS: sometimes you just need to go full retard.Comment
Tires are too tall. I know there are others who have successfully fitted them, but they will scrub the front inner fenders often.Comment
I think they'll look pretty good. Cut a coil on the front or use drop hats and it would look great.Well I found a deal on a set of esm 009r's, 16x8/16x9 staggered setup et20 front and et15 rear. Tires in the front are 205/45/16 and the rear are 215/40/16. Will this look stupid on my car? I am lowered on H&R sports and was wondering if there would be too much gap. Thanks.Comment
The fronts will be fine, actually A LOT more sunken in than the rears. If you're running those together I'd suggest at least a 10mm front spacer to even them out. No spacers on the rear.
205/45 and 225/40 will work fine.Comment
Hmm well I plan on doing quite a bit of auto-x and hopefully a couple HPDE's this summer so I want some decent tires. It seems that for 16's the widest you can get for an extreme performance summer tire is 225mm and always with a 50 percent aspect ratio.
I'm a noob to tire fitment. How much of a problem would the scrubbing be if I was doing auto-x? I mean I'd be using a lot of steering lock and what not.
I guess my other option is to run Kumho Ecsta XS's or Falken Azenis RT-615k's since they're available in 215 45 r16.Last edited by Adrian_Visser; 02-22-2011, 06:21 PM.
'89 Alpine S52 with goodiesComment
Okay this same setup but I bought some 15x7 Enkie 92 reps. I had to choose offset 0 or 20. I knew 0 would poke and Im not planning on stretching tires becuase that would be dumb on 7 wide, so I got offset 20. As for tires Im thinking 205/50/15, ive run this size on 15x8's with a hair of stretch so this should look normal. I do have rolled fenders and theres a good chance im gonna wanna run spacers to get sortaflush, i was thinking 10's or 15's, thoughts?Comment
Wheels are 7x15 ET35
Car is 1989 325i
Can I put 225 width tires on the back and 215 on the front?
What about sidewall? Should I get the smallest sidewall possible or the thickest?
How about 40 or 50 for the sidewall?
Car is just used as a daily driver for now.Zinno '89 <24v swap in progress>
