This is a sticky topic.
  • phreshkid
    • 4655
    #4156
    You can do anything you put your mind to lobar. Search 4 lug to 5 lug adapters. Learn offsets, center bores, hubcentric spacers, etc. It might take as little as an hour and as much as weeks to get the required information but the goal here is to learn the required information. It'll make you smarter and it'll waste out time less. Good day.
    • CabrioPunk
      • 1451
      #4157
      Spacers, tires, and fender rolling with this.....
      16x7.5 et30?
      I like flush.
      89 Vert. JOM coils will be used, try and just give a bit of wheel gap or so.
      I'm more low and slow. I think stretched Is cool but don't think for this appliction so 225/40s?
      • EndreM
        • Jul 2009
        • 513
        #4158
        17x8 et0, will it look stupid? And is it possible? Car is lowered 60/40
        '91 E30 316i
        '97 Rover Mini 1275
        • Mystikal
          Wheel Fitment Expert
          • 9602
          #4159
          Originally posted by GDA
          Ok, then should I run a 17x8 square setup and would 235/40 work?
          It seems Kaliboy runs ET 20 Style 5 with 235/40 on E30 M3 setup so just want to get some confirmation before I buy a whole set of tires...
          No, 235s won't work with the 17x8s either. Even on an early car with flatly rolled arches...it rubs. Been there, done that.
          • Mystikal
            • 9602
            #4160
            16x7.5 et30?
            I like flush.
            225/45 (or 215/45): 10mm front, 15mm rear.
            205/50 (or 205/45): 15mm front, 20mm rear.
            • Mystikal
              • 9602
              #4161
              On the front, yes. Unless you manage to get like 3.5* of camber.
              • Danny
                • 14216
                #4162
                Originally posted by Mystikal
                It'll come down to the exact tire model used. Some will clear, some won't (section width and rim protectors vary).
                Apex ARC8s with either 235/40/17 Star specs or 245 star specs.
                • CabrioPunk
                  • 1451
                  #4163
                  Thank you my brethen
                  • LuckyHenriksen
                    • Jun 2010
                    • 4244
                    #4164
                    What offsets would be ideal to run a 16x9.5 all around on a late model? Looking into adapters now, and I need to know how thick to order haha. I plan on running stretch/camber etc. so hopefully I can make them fit!
                    Bahama Beige E23 Project
                    Bluebird Bus Conversion
                    New Oregon Trail
                    • Earendil
                      • 1662
                      #4165
                      Sanity check. I could have swore I read something about this on r3v a while back, but now can't find the info.
                      Car: 89 325i on Bilstein and H&R Sport.
                      I'm thinking RD 1.3s (15x7 @ ET25) combined with either a 205/50 or a 225/45.
                      I shouldn't have any problem with this, right?
                      Last edited by Earendil; 03-08-2011, 01:06 PM. Reason: Edited the ET size I listed.
                      1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
                      2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
                      I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
                      • CabrioPunk
                        • 1451
                        #4166
                        What lugs will I then need? Gotta get this all priced out to shop around and make an order.
                        • bobross
                          • Jul 2005
                          • 753
                          #4167
                          Thanks for the recommendation dude!
                          Im LOVING the added traction and feel of the new Kumho XS'
                          I also picked up a set of lightly used tires for my 17'' setup based on your suggestion. i'll let you know how that goes too :)
                          -Greg
                          90 325isT - 12.2 @ 120ish - Dyno Results
                          b18c5 EG Coupέ - 13.5 @ 100ish - Dyno Results
                          • Mystikal
                            • 9602
                            #4168
                            Can't say for sure. Worst case throw some cheapie 3mm on the front.
                            • Mystikal
                              • 9602
                              #4169
                              +5 is enough to clear the front struts (and more than enough for the rear).
                              • Mystikal
                                • 9602
                                #4170
                                Perfect fit, no fender mods. 225/50 is possible also, although yes tire selection is crappy.
