This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #4186
    Originally posted by MisterMiniS
    1989 325i, completely unmodded. Getting some 15x8 et36 with some 225/45/15 tires for autox. Will this rub the strut? Thanks for the help!
    Yes it will. 15mm spacers all around.
    • Mystikal
      • 9602
      #4187
      Originally posted by 89AlpineM3
      I have a 91' 325I vert and I want to run a set of 17" style 5's that I had for my M3. I will be using 18mm adaptors/spacers on 205 tires. Will this work? and will they be sticking out too much?
      No, they won't work well at that offset (assuming you mean 17x8 +20 E39 Style 5s).
      • Mystikal
        • 9602
        #4188
        Originally posted by IronmanE30
        Thank you for your comments. What is your recommendation for a good tire for daily driving performance in that size.
        Thanks,
        Jim
        Rank these:
        Dry
        Wet
        Hydroplaning
        Ride
        Noise
        Response
        Price
        • IronmanE30
          • Sep 2009
          • 2121
          #4189
          Originally posted by Mystikal
          Rank these:
          Dry=9
          Wet=4
          Hydroplaning=4
          Ride=6
          Noise=6
          Response=8
          Price=5
          I live in Calif and won't be driving the car very much in the rain. I don't want a super soft tire but I don't need to get 40K miles out of them either. A tire that feels the road and is fun to drive is my goal. Hope this helps. I would like to keep the price per tire under $150 if possible but if the best tire for my needs is slightly over that price it would be ok.
          Cheers,
          Jim
          • 5ickride
            • 2922
            #4190
            Tire fitment help
            What tire size can i run on a set of 15x8.5, 15x9?
            • Mystikal
              • 9602
              #4191
              Cheers,
              Jim
              We're referring to the 205/50, right?
              With your dry traction and response goals you will have to sacrifice treadwear. Around 15-20k can be expected. You can offset this by purchasing one of the less expensive options: Falken RT-615K, Hankook R-S3, Kumho XS. All of these are phenomenal and will pretty much transform any E30.
              • Mystikal
                • 9602
                #4192
                Offset suspension car year fender mods...info please.
                • 5ickride
                  • 2922
                  #4193
                  Bbs RM 012
                  Front: 15x8,5 ET7 57,1 4x100
                  Rear: 15x9,0 ET0 57,1 4x100
                  Stock suspension at the moment but will be looking at bilstein sports and possibly HRs Sports.
                  1991 318ic everything stock....for now ;)
                  • Mystikal
                    • 9602
                    #4194
                    Bbs RM 012
                    Rear fenders will have to be pulled, fronts a flat roll. Car will also need to be much, much lower than H&Rs to pull off that setup. 205/50 all around.
                    • IronmanE30
                      • Sep 2009
                      • 2121
                      #4195
                      Yes, and thank you for your input.
                      Cheers,
                      Jim
                      • QUKBMER
                        • 8178
                        #4196
                        Jim also check into NITTO NEO-GENS' 205/50/15 HR/VR. 15-20K These tires worked bitchin for me daily driving to work and canyon spirited driving.
                        Terry.
                        • 5ickride
                          • 2922
                          #4197
                          Ohh, really? Like IE3s or HR Race? Potholes here suck ass and i dont want to slam it and risk the oil pan and shit
                          • blalor
                            • 217
                            #4198
                            I've got a set of 15x7, 40mm offset Team Dynamics Pro Race 1 wheels I want to use on my '91 318is. I've got 3 sets for my MINI (2006 R53) and would like to be able to get a little crossover between the vehicles in my household. :D I currently have basketweaves and finding suitable tires for the track in 14" looks to be an almost impossible task. 15" isn't all that much better, honestly…
                            I did some test fitting on the driver's side front with the new Dunlop DZ101 tire I got for my MINI yesterday. 205/55-15. I cobbled together a 6mm spacer from some aluminum and it still wasn't enough to clear the strut, so I think I need at least a 10mm spacer. I haven't tried the back, yet. If I can keep this thing running long enough, I may end up running dedicated track tires, in which case I'd probably go as wide as 225.
                            The car's been lowered by the previous owner; it's on Bilstein shocks, H&R springs (I think). I don't know how much it's been lowered, but it's not obscene. It's on 205/60-14 Yokohama ES100s right now.
                            The wheels have a 73.1mm centerbore, so I need to use centering rings.
                            What spacers do I need to get these wheels to fit with 205 (and ideally 225) rubber? What length lug bolt do I need?
                            • blck325is
                              • Apr 2006
                              • 1749
                              #4199
                              Does anyone know where I can get 20 hole barrels for 2 piece, 16 inch wheels.
                              Originally posted by csermonet47
                              Vlad, you are handling this quite unprofessionally.
                              Also, you are a cock with tacky taste.
                              That is all.
                              • stinkydriverx
                                • Jan 2008
                                • 501
                                #4200
                                Hey J,
                                Im looking for a little more info on fitting a 225/50 on a 15x8 et 20(trm c1)..
                                How much fender work is needed? Im already rolled and slightly pulled all around. Im on coilovers and have camber plates in the front.... Because I know some brands might be wider or not.. Im specifically looking at the g-force sport in that size...
                                Thanks man,
                                Andrew
                                Turbo m30 drift car build.
                                500whp or bust.
                                http://www.r3vlimited.com/board/showthread.php?t=256525
