	This is a sticky topic.
 What's the rear offset?Mystikal,
 I have 205/50 on 16x8.5 et32 and 225/45 on 16x9.5. What adapters do you recommend? I have seen other guys running the 16x8.5's front and rear with 20mm adapters but with 195/45 tires. I foresee clearance issues, if I copy the same set up, since those tires are far more stretched than what I have. I have a late model car, lowered, and do plan on doing some fender work. Please advise, thanks.Comment
 I am looking into getting 16 x 9 keskin kt1s. I know from reading some threads that the et had to be a certain size to clear the front brake setup. What is this et because the et of these wheels is 15.
 Also would 205/50/16 work on an e30 lowered on JOM coilovers? I do plan on rolling my fenders, but not pulling. If this tire size would be too stretched or not a big enough sidewall please let me know. I really was trying to stay away from 55 series tires because a friend of mine has them and I think they look too beefy for an e30.
 Also is anyone on here running these wheels in 16 x 9 because ive seen a bunch of the 17s but im interested in 16s.
 Thanks
 INSTAGRAM @ merlow_
 hi there
 I need some help, I've searched but can't find a definite answer. I'm doing a 5lug swap (e36 m3 front and z3m rear). What wheels and size and ET should I be looking for? I want a wheel similar to bbs style 5 like 17' x 8 maybe but they need to clear de e36 setup without crazy mods to the fenders..
 THANKS !! :)e30 325is
 MODS:
 s52 obd2 swap
 Z3 M 5 lug conversion
 Apex 17' wheelsComment
 I'm looking into getting new wheels they are 15's
 15x8 et13 up front and 15x8.5 et06 Tires: 195/45/15
 Will I have any clearance issues clearing the calipper or rubbing?
 Thanks!Comment
 Need wider contact patch.
 Mystikal, et al.,
 Current setup:
 - 1987 325is w/ 4-bolt hubs
- Bilstein Sport front
- Koni SA rear
- H&R Race springs
- Racing Dynamics sways - 22mm front / 19mm rear
- E30 M3 camber bushings
- Dinan fixed camber plates - 3°
- UUC BBK (see attached fitment template)
 I want to stay with 16" rims.
 Is it possible to run 235s? What offset will allow the widest tire width?
 I Timothy 2:1-2Comment
 Need some help - i'm a complete noob when it comes to wheels and fitment:
 I'll be running filled-and-drilled 16x8 et23 style 5s (from an e38 ) with 5mm spacers on my 318is, lowered on IE3 springs. I've got 205/50/16 Falken Ziex tires to mount, but really want to go wider to avoid the stretched look, and gain a larger contact patch. Ideally I would go 215/45/16. I don't want to roll my fenders, though! Any thoughts on whether or not this it's possible to run 215/45/16 without rolling fenders? a 40 series tire might work, but i'd like to keep the ride height as high as possible - I already scrape too much!
 Thoughts? Thanks!Last edited by misterTT; 06-13-2011, 03:43 PM. Comment
 I have 205/50/16s on 16X8 ET25. I had to roll the fronts. Once I did, the 245/45/16 Falken Azenis RT615s didn't rub, either.Need some help - i'm a complete noob when it comes to wheels and fitment:
 I'll be running filled-and-drilled 16x8 et23 style 5s (from an e38) with 5mm spacers on my 318is, lowered on IE3 springs. I've got 205/50/16 Falken Ziex tires to mount, but really want to go wider to avoid the stretched look, and gain a larger contact patch. Ideally I would go 215/45/16. I don't want to roll my fenders, though! Any thoughts on whether or not this it's possible to run 215/45/16 without rolling fenders? a 40 series tire might work, but i'd like to keep the ride height as high as possible - I already scrape too much!
 Thoughts? Thanks!I Timothy 2:1-2Comment
 They're +15, and that's the correct version, but you'll still need spacers to clear the struts. 3-5mm is fine.I am looking into getting 16 x 9 keskin kt1s. I know from reading some threads that the et had to be a certain size to clear the front brake setup. What is this et because the et of these wheels is 15.
 Thanks
 205/45/16 tires are what you want.Comment
 Going to need a test fit to see if they will clear without spacers. They just should, but if the tires run wide or have abnormally large curb protection then you will need small spacers on the front.Comment
 +30 to +42 offset wheels, give or take a bit.hi there
 THANKS !! :)
 Note that your offsets are going to be all out of whack if you're using Z3M axles. You'll need 15-20mm spacers on the rear to even out any non-staggered wheel setup.Comment
 Caliper clearance is more a factor of wheel design than specifications. You'll have to test fit them, unless they're widened RMs (paypal me $20 if I'm right :p) in which case they clear fine.Comment
