	This is a sticky topic.
 I don't know the offset of the wheels nor the dimensions of the fender flares. But...no. Tires are way too tall for an E30 chassis.Comment
 17"x9" +20 front
 18"x9.5" +35 rear
 So lets say I raise my spring perches about an inch to clear the taller tires I'm assuming Ill need at least a 20mm spacer for the front, and Ill have about 10-15mm of clearance between the wheel and the strut in the rear. Am I correct in my thinking here?Last edited by e30Rooster; 02-24-2012, 05:59 PM.sigpicComment
 Will i need spacers to use 17x8 20 offset wheels? What tire size would work best? I plan to lower the car a little in the future.
 thanksI'm not a real car guy :(Comment
 Actually my question was kind of vague. I am looking at some 17x8 style 5 BBS for either my E30 Mtech2 or my E30 m3. The wheels I am looking at are I believe et20 hub bore 71?mm.
 Will these fit the M3 without spacers? If I fill and redrill can I use them in my E30?I'm not a real car guy :(Comment
 I'm 90% sure its been asked already but I can't seem to find it.
 Looking to run 17x8 et20 style 5s with 18mm adapters.
 will it rub?
 What options do I have for tires?
 I have a pair of 245/35 and 215/40
 mtech1/2jzgte/r154/275tire
 function>formComment
 I have been told you cannot run 245/35
 You will have to ge tthe 215/35 double checked.Comment
 Should of went with 205/40R17 instead of 215/40R17 ugh ! Or will it tuck inside nicely when lowered ??Comment
 On the front 15mm spacers are probably enough, but good luck clearing the wheel well, chassis seam at the top, and other parts. Rear, you'll be having clearance issues with the trailing arm. Massively tall, bubbly tires means that I have no idea how much spacing will be needed.17"x9" +20 front
 18"x9.5" +35 rear
 So lets say I raise my spring perches about an inch to clear the taller tires I'm assuming Ill need at least a 20mm spacer for the front, and Ill have about 10-15mm of clearance between the wheel and the strut in the rear. Am I correct in my thinking here?Comment
