This is a sticky topic.
    Originally posted by devon.818 View Post
    found some borbet LS wheels.
    size 16x8 with 205/45/16's mounted.
    offset is 1 inch.
    will these clear? could i get away with running a spacer in the rear to get a lil more agressive look?
    EDIT: they are coming off a miata with center bore of 54.1. how expensive would it be to get these bored out to 57.1?
    You will need a 3mm spacer to clear the front struts. I'd suggest a 12mm in the rear to even out the fitment.
      Originally posted by RagtopE30 View Post
      Mystical-
      I picked up a almost new set of Kumho V710 tires. The size is 225/45/R16.
      My car has a moderate amount of fender roll and I am currently running 225/45/R17 without an issue but I am not sure of the offset of the Kosei wheels that I am running.
      My question is, What would be the best wheel size and offset for the Kumho tires? I autocross so they will not be used for DD. 16x8 or wider?
      16x8 +20.
        Originally posted by GunMetalGrey View Post
        17x7.5 42mm offset
        Biggest rear tire possible?(handling purpose)
        Best front tire size? (Handling again)
        Spacers needed? If so, what sizes?
        Rear fenders may get bolt on flares
        I am on coilovers
        15mm spacers all around, 235/40/17 tires all around. Will not need flares, you'll barely even need to roll.
          Originally posted by CrusherCurtis View Post
          17 x 10 et 15 (ESM BBS reps)
          Will these wheels poke on the rear of a non lowered E30? It seems like on lowered cars the added camber helps to kinda tuck the top of the wheel in. Also would be mounting on a 40 series tires with no stretch. On the lowered e30 in this thread they look great ( http://www.r3vlimited.com/board/show...=194274&page=5 ). I'm just wondering how they would look with slightly wider tires on a stock ride height
          Stock height + 17x10 + non-stretched tires = monster truck. Just don't do it!
            Originally posted by maniacmatt View Post
            Here are a couple of set-ups I am thinking about.
            First, I was thinking of running a 225/45/16 BFG KDW on these wheels.
            Front 16x8 et20
            Rear 16x8.5 et24
            Secondly, for a really grippy set-up I was thinking of running a 235/40/17 or 245/40/17 Dunlop Z1 SS on a 17x7.5 et33.
            First setup is ideal. Fender roll needed in the rear.
            The 17s will likely need a small spacer to clear the front struts with a 235/40 (5mm). 245/40 isn't ideal on the 7.5.
              Originally posted by mtechnik View Post
              Slightly different question...
              I recently bought a used Michelin PS2 with the following DOT code: FT2 x 0203 H202 . I can't seem to find any evidence on the net that the Pilot Sport 2's production dates as far back as 2002/2003.. So what's this tire's real production date?
              No idea.
                Originally posted by Broom Broom View Post
                Looking at purchasing some 17x8.5 esm 002 wheels for a stock e30 what is the best tire to run for stretched and non stretched and what offset should I choose? These wheels are available in 15 and 20
                Will I need to roll fenders or use spacers/adapters
                Thankyou
                20 offset and 215/40/17. Will still require a fender roll despite the moderate tire stretch.
                  Originally posted by Tobin View Post
                  I have decided to get a set of the ESM-004's, but I could use a little help on the fitment. I have an 1987 325is with the IE Stage III springs, Bilstein Sport shocks, adjustable front camber plates, sway bars, all the bushings, etc. The car will be getting painted after fitting the wheels, so I am open for (and expecting) some aggressive fender rolling/pulling. The car obviously sits quite low on the factory 195/65R-14 tires, so I am planning for the new set up to be slightly taller overall. I understand this will affect my gearing, but I would like to run 245/40R-17's all around. Unless someone says different, I am expecting the 17x8 et 20 wheels will be the best way to accomplish this. A few questions:
                  1. From what I have read, I believe this will require spacers on the front, any idea what size to clear the front struts?
                  2. Any reason to think the rears would require spacers?
                  (These belong in other threads, but it's worth a shot)
                  3. If I am getting spacers, what is the latest recommendation (brand) for swapping to wheel studs?
                  4. Who is currently loaning/renting out their fender roller in the Houston area?
                  Thanks for the help,
                  Tobin
                  Won't need spacers at all. Will need significant fender rolling/pulling in the rear and a good amount of front camber to fit though.
                    Originally posted by mtlbloodshot View Post
                    I recently got Avez Type A for my 318is.
                    Wheel specs are:
                    16 x 7.5 ET 20 ( front)
                    16 x 9 ET 15 (rear).
                    I am repainting the car this winter and yes im rolling both rear and front. Questions is:
                    What size tires will I need to have a flush stance? Ill be running GCs. I was told to run 205/40 all around. Any suggestions?
                    205/45 all around, or 215/45 225/40 in the rear as an option. Fronts don't need rolling, don't bother risking it.
                      Originally posted by lbreevesii View Post
                      I know this has probably been answered somewhere in here before, but jfc this is a huge thread!
                      I'm dropping an upgraded S50 into my E30 and want to run beefy tires, probably a 17x X wheel. What sizes and offset can I run with a mild fender roll to maximize my tire size? Car will be pretty low on GC's.
                      Apex ARC-8 17x8. I spec'd the offset on them to run 235/40/17 on the E30 without any modifications other than a mild rear fender roll.
                        Cool, 235 it is then, should still be plenty of grip.
                        Thanks for providing your expert insight.
                          Thanks for the input. What offsets? How about something in a meshie. I like the arc-8 style wheel, but think i'd rather go mesh in the long run. I've got a set of 16x7 enkeis that i'm running now that are a similar style to the arc's.
                          I don't always wreck cars, but when I do I wreck them into trees.
                          91' 318is S50 swap - The Black Widow
                            Won't fit.
                            Can you elaborate a little? The 225/50/16 is only .78" greater OD than the stock 205/50 the car came with?
                            Can I even run a 205 on an 8.5" wide wheel? That's a full inch wider than the manufacturer recommends for that size.
                            2012 MCSCC/NSSCC CP class champ
                            HSAX Instructor
                              I know the answer is buried somewhere in this 300 pages.....
                              Mystikal -
                              16x7 ARE 398 et25
                              IE3 springs and e90 drops hats
                              Fenders are not rolled
                              What say you
                              Always Always go for the reach around if there is an option
                                Tire brand, size combo's and fitment question. Opinions wanted. Car is a 89 325i lowered on vogtland springs probably a little lower than h&r race springs...I plan on going with h&r sports as the car is just to low.. Rims are 16x7.5 lenso bsx not sure on the offset..
                                Questions:
                                Would I be able to fit 225/45/16r's front and rear?
                                The tires i have in mind is the Nexen N3000 all season and Falken FK-452's seems to really be my only all season choices
                                I have heard some people say that the 225/45/16 may not fit up front, if this is he case and I ran 225/45/16r's in the rear, what would be a suitable size to run up the front..?
