This is a sticky topic.
    Originally posted by ACHTUNG View Post
    Jay - You would suggest the same size tire for a staggered setup? You wouldn't go with a wider tire on the wider rear wheels?
    Depends on the setup.
      Originally posted by Ant_e30 View Post
      I picked up some 15x7 +20 Zender Turbo rims cheap off a local guy which have bald 205/50s on them. The 205s are a little bulgey on the 7".
      I plan to get them refurbished professionally and make them look nice as a stop-gap wheel. I enjoy aggressive fitment but on skinny 15s it will be hard. When i install them, i will be running a full coilover setup.
      My thoughts were to run 25mm front and 30mm rear bolt on spacers and roll the guards. What size tyre would suit this combo? Judging from the bulge of the 205, i was thinking 195/50 or even 185/50 if that is possible to buy.
      My concern is making the small and narrow wheels look awkward if spaced too much with too small a tyre. However i only want to use bolt-on type spacers so the minimum for these is often 25mm.
      cheers for any input...
      It won't look very good. From the rear it will look downright strange. Wouldn't suggest trying to go flush on 7" wheels.
        Originally posted by Mystikal View Post
        Well then you went too small. Throw a 5mm spacer on the rear and roll. :D
        Haha damn! I did notice the clearance with the front strut is pretty tight. Should I be concerned or throw on a small spacer for good measure?
        91 318is M50 swapped
        05 Honda Pilot
        24V swap thread
          Anyone ever run these? http://www.jegs.com/i/Weld-Racing/92...oductId=755790
          Be great for cook 225s
          sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
          The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
            Jay -
            Car: 1989 325i on Bilstein's and IE3 springs
            Fronts: 16" 7.5" ET25 with 225/50/16
            Rears: 16" 9.0" ET15 with 225/50/16
            Here are my questions:
            Would there be rubbing or fitment issues with the following setup?
            Would the rear poke?
            Does this seem like a good tire choice?
            Do people run the same size tires on staggered setups like this?
            Would spacers be needed on the fronts for them to be flush with the rear?
            1989 US E30 Cammed S52
            Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
              I want to get the esm-002's...what offset do i need to get for my e30 if I want the 16x7.5 in front and 16x 9 in back?
              4x100 pattern. Thanks
              1985 325e
              mods:
              Powerflex CABs
              MOMO Corse Exhaust
              euro bumpers with BBS front spoiler
              e36 m3 shifter
              uuc clutch stop
                Spacer has nothing to do with clearance, just to even out the stance. You'll see what I mean once you mount the wheels.
                  Jay -
                  Haha, tire sizes are way off. 205/45 front 225/40 rear with rolled rear arches. Fronts will need 15-20mm spacers to look anything like the rear.
                    +20 front and rear, if they still offer them. I'm not searching to check.
                      Jay -
                      I'm running 225/50/16 on my 16x7 et25 and it took rolling of all 4 corners (including the rear "high arches") and removal of the front fender liner to get no rubbing. I have E90 drop hats, billies, and IE3 springs.
                      Always Always go for the reach around if there is an option
                        trying to fit 16x8s on my car at height in sig. what size tires wouls i need to stretch on there to make this happen? front et20, rear et10
                        400/650lbs coils.
                        1989 LN106 Hilux / 3.0TD SFA
                        1974 2002tii / stock
                        2002 IS300 / 5spd LSD
                          Will 17x8 +35 and 17x9+35 BBS RS with H&R Race springs fit? I'm thinking of doing a fill and re-drill and using spacers if needed.
                          Feedback
                          Instagram - @e30_mtech2
                            School me on these wheels,please. Tell me if they are cool,lame or even rare? Also, what kind of BMW they came off of. Shop near mine deals with nothing but take offs.
                            Wheel #1
                            Wheel #2
                            Wheel #3
                            This is what I'm up against.:shock:
                            88 M3 Diamantschwarz
                            89 M3 Zinnoberrot
                            56 Isetta
                            LIKE ARCHIE'S on Facebook!
                              How about 215/45/16 Falken RT-615k on all four corners?
                                Wheel #1 is Style 32 could be from an E39/E46/E65/E90 (Depending on the size/offset)
                                Wheel #2 is Style 5 v2 off of an E38/E39
                                Wheel #3 is NOT a BMW wheel. It is from a 90's Jaguar XJS.
                                There are way too many wheels on those pallets. All of them look familiar.
                                Which ones are you interested in?
                                » PARTS FOR SALE
                                » TRANSACTION FEEDBACK
