Originally posted by Mullet Bullet
View Post
This is a sticky topic.
Hi Mystikal,
please help for tire fitment
Car: 1991 BMW e30 m40
S/A : Bilstein
Lowering Spring : Jammex Sport-kit
Rims # 01: BBS RS023
(Original set 8x16 et.24 - 1.5" lip, 6" barrel)
already change to;
- front 7.5 x 16 (change original barrel to 5.5")
offset change to et.18 (plc cmiiw.. )
- rear 9 x 16 (change original lip to 2.5")
offset change to et.11 (plc cmiiw.. )
? please info what tyre is suitable for this set
Rims # 02: BBS RS071
Original set 8x15 et.18 - 2" lip, 5.5" barrel
but i found this rims is change to 6.5x15 et.37(?) - 0.5" lip, 5.5" barrel
i want to change the lip, can you help me suggest what lip to choose if i want staggered look for daily use ?
is it 1.5" front and 2" rear or 1.5" front and 2.5" rear ?
also what tyre to fit the setting ?
Thank you
What size adapter/tire size should I run for Corvette salad shooters on a late model e30, if I'm shooting for a flush fit. I've seen varying setups so I wanted your opinion.
I will be running GC coils as well. I'm not afraid to roll my fenders either as long as its not a ridiculous amount.
PCD: 5x120.65
16x8.5 et32
16x9.5 et38
S/A : Bilstein
already change to;
Thank you
Originally posted by noE30 View PostWhat size adapter/tire size should I run for Corvette salad shooters on a late model e30, if I'm shooting for a flush fit. I've seen varying setups so I wanted your opinion.
PCD: 5x120.65
16x8.5 et32
16x9.5 et38
Originally posted by Mystikal View Post205/45 front 225/40 rear. Rolled rear arches. If you're worried about fender work 195/45 front 215/40 rear.
Thank you for your suggestion.
This is the picture of my old setting
front r16x7.5 (195/50) rear r16x9 (205/50)
not good setting:
I do not worry about fender work, my front and rear fender already rolled.
so 205/45 front 225/40 rear...
But how about 225/45 on the rear, still rubbing ?
Originally posted by Mystikal View Post8mm spacers can be trouble on an E30 as the wheel would have zero or next to zero hub lip to sit on. On the rear though, you'll probably get away with it. Learn to torque the bolts in the proper star pattern prior to lowering the car down and you can lessen/avoid any wobbles.
the wheels are 17x8 et 25 do you think it would still be an issue? i heard this specific wheel is not ideal to run a spacer with that size?
Wheels: Azev A - et20 16x7.5
Tire Desired: N.A
Tire Size: N.A
Suspension: H&R Sport / Bilstein Sport
Chassis: 88 325is
I'm inquring about 225/45/16 size tires. Will there be rubbing of any kind? Body is all stock, fenders never rolled. Better bet to go 205/50/16? Mainly for daily driving & hard parking. :D
1.5" front 2.5" rear is nice. It's tough to find tires the right diameter for an even stretch though, I'd suggest 195/50 front 205/50 rear for something close.
thank u for this advice,
For my consideration please info if:
- the front lip change to 2" lip (=> r15x8 et.18)
- and the rear with 2.5" lip (=> r15x8.5 et.12)
Please advice the tire fitment
Thank you..
