Originally posted by rnw
View Post
This is a sticky topic.
Originally posted by Mfever View Postthe wheels are 17x8 et 25 do you think it would still be an issue? i heard this specific wheel is not ideal to run a spacer with that size?
Originally posted by Bimmerista View PostWheels: Azev A - et20 16x7.5
Tire Desired: N.A
Tire Size: N.A
Suspension: H&R Sport / Bilstein Sport
Chassis: 88 325is
I'm inquring about 225/45/16 size tires. Will there be rubbing of any kind? Body is all stock, fenders never rolled. Better bet to go 205/50/16? Mainly for daily driving & hard parking. :D
Originally posted by SilberSurfer View PostHi,
Have a set of staggered BBS RS
RS001 15x7 and
RS002 15x8
What tire size should I run ?
Same all around ? Wider in rear?
Originally posted by Mystikal View PostUnless you're willing to pull your fenders, you're stuck with 205/50 all around. Even then your rear arches will need to be rolled.
205/50 ? Not 205/55 ?
Thanks.
Hi mystikal,
Good day to you.
Originally posted by Mystikal View PostThe rears are 16x9 +11, right? 225/45 will need substantial fender work, don't do it. 215/45 can work if the spring rate is high enough and the fender is rolled flat.
Originally posted by Mystikal View Post205/50 all around.
i have two sets of wheels.
whats the largest spacer i can use? i have front camberplates currently set at (-4). rear camber is at (-3) at its current height. should also mention adjustable height with 500f/600r springrates
wheel 1: (e34 style 5) 15x7 et20 with 195/50/15 tires. (need spacer for brake clearance in front)
wheel 2: (euroweaves) 15x7 et24 planning on 205/50/15Last edited by tonywonder; 09-25-2011, 12:10 AM.
From looking through all the post it seems the widest tire people are running is 245's.
I'm wondering if anyone runs wider than this?
If so, what kind of offset are you running? What suspension?
My question is because i'm building a ls1 car that will be putting down atleast 400rwhp.
EDIT: Car is a 1987 325IS
