	This is a sticky topic.
 My 1989 e30 s52 Touring... this is Betty
 My 1989 325i vert (sold)...this is Nina
 My 1991 M5 (sold)... this is Veronica
 Photo comparison: OEM vs aftermarket windscreen for a convertible
 So if I went with a 8.25 would that take car of the issues? (same offset ect) then what tire would I wantYou will need 20mm front spacers just to clear the struts. At that point the wheel will be far, far outside of the fenders.
 Tire sizing completely depends on how much space you're adding with pulling and/or flares. Basically nothing will fit using my normal guidelines (fender roll, stock body).Comment
 I'm trying to make my 16" wheels work, so would a 245/35/16 on a 16x8.5 ET25 wheel fit in the rear?
 Photo comparison: OEM vs aftermarket windscreen for a convertibleComment
 alright
 My wheels are 17x8.5 et13, I need an 8mm spacer with these wheels to clear my callipers.
 What does this calculate into for the perfect offset? or am i reading completely wrong into this?
 just trying to find a nice set of wheels that will work with the bbk.
 mtech1/2jzgte/r154/275tire
 function>formComment
 17" style 5s or style 19's, both 17x8 et 20. How doable would those be on a 89 coupe if you ran 18mm adapters? I haven't had any luck finding any one running something similar.
 Might have to look for a place that can re drill.Comment
 will 15x8 with 4 inch backspacing and a 205/50 tire fit in the front of my early model? the back will be 15x8 with et0 so im not worried about those. Just the frontsGetRealWeird.com
 For all your daily entertainment needsComment
 I'm about to buy some BBS RS's and am a little worried about fitment. The specs are 16x8.5 with et18 in front and 16x9 with et12.5 in the rear. My car is lowered on the turner motorsport suspension setup and its already a tight fit with 15x7et25 dforces. Will i need a spacer in the front?Comment
 So a slightly oversized tire (215/50) is not recommended? Why not? i always liked the look of tires a slightly larger diameter and it should be okay gearing-wise because the car already has a 4.27.I very much agree, I've been steering people away from 215/40 as much as possible in recent years. It became the de-facto 16x9 size for reasons that I do not understand. It looks silly unless your oil pan is 1.5" off the pavement.
 205/45 or 215/45. The sizes you mentioned will not work.The first car I ever rode in was an e30
 1992 Mauritiusblau Vert
 2011 Alpinweiss 335is coupe
 2002 540i/6 Black/Black
 2003 GSX-R 750 (RIP)Comment
 At a guess I would say they would get pushed way out of the arches when using adapter as they normally are quite thick (20-25mm?).
 Anyone run 16x9 et15 with 225/45/16's? Looking at a tyre size calc these are close to stock 205/55/15's. I can do what ever work is required before resprayComment
 245/40-17 or 235/40-17 on a 17x8.25 with ET20.
 E30 M3 Front/rear fiberglass quarters. Possible? I can "space" the rear fender out if I need to. I know I'm running into the issue of the tires being oversized (diameter), but it's a track/drift car. What size spacer would you recommend, if any? Comment
 Yes, +23 will clear with a flat fender roll.
 Bump it up to +28ish for a 245/40.Comment
