This is a sticky topic.
I am looking at a set of wheels that are 17x7.5 et 20
however I believe they are for a nissan cause the center bore is 59mm.
Wheels are ATS Comp Lites.
Questions:
1. Can I get away with not running any sort of hubcentric spacer. The car has studs if that makes a difference.
2. Does anyone make a 59 to 57mm adapter?
3. My car is on Konis and GC coils. 550f/750r. I plan on using my current 16s for track wheels. What tire size for the 17s would be good for the street. I would prefer to run a 225/45 but I am not sure how that would fit. Tires are probably federal s595s as I have good experiance with them.
Thoughts?
215/40 is the size.Comment
sup i have a 1991 e30 vert.
got some bmw style 5, bbs rc090 17x8 et20 all around. i'm also running the 4-5lug conversion spacer/adapter kit which i believe is a 20mm (correct me if i'm wrong). it's the one rob sells on the forum. i am planning on buying a set of the coilovers from groupbuy #3 on the forums as well.
q's:
1-what tires size should i run with this setup?... i'm sure it's a pretty common one, excuse me if it's been covered over & over. this thread is getting pretty loooonnng.
2-if stretch is needed, what brand/model tire do you guys recommend is the best?
thanks for your wisdom!
markComment
Hey Mystikal,
I've got
1990 325i (4 door 5 speed) if it matters
15x7 et28 RacingDynamics wheels
205/55-15 Yokohoma S-Drives
H&R sport springs
Billy sport shocks/struts
I want to swap to a set of IE3 springs with no front pads, and install an e36 steering rack. What size spacers should I order to assure I wont have any full lock rubbing issues while still getting a bit more of a flush fitment?1990 332i, 4 door
2008 KTM 990 Superduke
2018 Golf R, 6spd manual (Pending delivery)
2017 Mazda CX-5 GT
2007 Z4M Coupe - Sold to very nice peopleComment
What is the max width tire that can fit on a 7 inch wide rim? My 205/50/15 tire ripped during the install. A local shop on my 15x7 rim'01 e46 330ci blk/blk (GF stole from me)
'90 e30 325i Traded
'95 e34 540i/manual swap (electric fire)
'96 miata M-edition (not quite an e30 so i got below car)
'93 Audi Urs-4 (like the e34 but still not an e30)
:hitler:Comment
sup, ok so i just picked up some 16x9 et12 im having them re-drilled to 4x100 .what tire profile will i need. For a nice stretch?? will i need spacers to fit the fronts ??will rolling fenders flat be ok or will I need to flare the fenders out as well??Last edited by StreetMafia21; 05-11-2012, 08:53 PM.Comment
16x9
Et25
DTM flares, which adds two inches out on the flares.
Coilovers
I want the tires to be filling out the flares, but not have to worry about rub, I can run spacers no problem.
Same size tires all around.
From what it sounds 245/45 with 15mm spacers all around?
Could I get away with a 245/50? In order to get road tires lolLast edited by GunMetalGrey; 05-13-2012, 09:20 AM.Comment
q's:
markComment
Hey Mystikal,
I've got
H&R sport springs
I want to swap to a set of IE3 springs with no front pads, and install an e36 steering rack. What size spacers should I order to assure I wont have any full lock rubbing issues while still getting a bit more of a flush fitment?Comment
