	This is a sticky topic.
 Originally posted by MystikalThanks!Originally posted by balooshinakusHello,
 I'm looking to put 235-40-17 tires (star specs, maybe rcomp in the future?) on my car.
 I have an early model with e36m3 front suspension and inline6 z3 hubs on stock trailing arms in the back. I'm running about -2degree rear camber right now and about -3 degrees up front.
 I'm looking at getting 17x8 rims, but I'm not sure what offset I need. How easy of a fit will this but? My rear fenders are currently rolled a little bit, but the front isn't. Will I need to do a bunch of rolling to run these tires?
 Which Z3?
 The inline 6 z3 (non-m) hubs on stock e30 trailing arms. I believe this adds about ~23mm to each side of the car but I'm not 100% sure on that number. Front suspension is e36m3 (coilovers).
 I'm wondering if I can get away with et38 17x8 rims (back is rolled) or if it will stick out too far. What would the ideal rim offset be?
 Thanks!Comment
 Yes, the non-M 6cyl Z3s had the long axles. 17x8 +38 should be perfect for your setup.The inline 6 z3 (non-m) hubs on stock e30 trailing arms. I believe this adds about ~23mm to each side of the car but I'm not 100% sure on that number. Front suspension is e36m3 (coilovers).
 Thanks!Comment
 hi, im looking to run 17 rims 10" rears et15 and 8.5 fronts et 20..... on 1989 e30 325i the car will be slammed on bc racing coilovers with the arches well rolled, also streched tyre all round........ i know it will be tight but any advise on this set up would be great. thanksLast edited by jimmy mac; 05-03-2012, 04:33 PM.Comment
 16x9
 +25
 Square setup, full size tires. Coilovers. I wouldn't mind running the dtm flares. Spacers are fine.
 What is the best size tire I could stuff under it?Comment
 I am looking at a set of wheels that are 17x7.5 et 20
 however I believe they are for a nissan cause the center bore is 59mm.
 Wheels are ATS Comp Lites.
 Questions:
 1. Can I get away with not running any sort of hubcentric spacer. The car has studs if that makes a difference.
 2. Does anyone make a 59 to 57mm adapter?
 3. My car is on Konis and GC coils. 550f/750r. I plan on using my current 16s for track wheels. What tire size for the 17s would be good for the street. I would prefer to run a 225/45 but I am not sure how that would fit. Tires are probably federal s595s as I have good experiance with them.
 Thoughts?Comment
 205/40 and 225/35hi, im looking to run 17 rims 10" rears et15 and 8.5 fronts et 20..... on 1989 e30 325i the car will be slammed on bc racing coilovers with the arches well rolled, also streched tyre all round........ i know it will be tight but any advise on this set up would be great. thanksComment
