This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #5446
    Originally posted by mashpro
    I have a set of Style 5's 17x8 et20 with adaptec 4x100 to 5x120 adapters that I want to run on my e30. What do I need to do to make this work and what tire size can I run?
    205/40 is the common choice. You'll need to roll and maybe pull your rear fenders for clearance. Same with the fronts if you're VERY low and don't have camber plates.
    • Mystikal
      • 9602
      #5447
      Originally posted by kreasims
      Jay, need your advice....
      Will 18x8.5/9.5 et 25 wheels fit E36 sedan? Recommended tyre sizes?
      Thanks a million :)
      Yup. 215/35 front 225/35 rear is ideal. You'll need a rear fender roll.
      • mashpro
        • Jun 2011
        • 59
        #5448
        Thanks for the info!
        • kreasims
          • Jan 2009
          • 149
          #5449
          Thanks Jay :D
          • KVF
            • 297
            #5450
            205/60/14 on the stock weaves (14x6.5 ET30 bavauto springs with billies)... What spacer size would you recommend to get as far out as possible without having to roll fenders? Would an 10mm be possible?
            Thanks!!
            • Mystikal
              • 9602
              #5451
              Thanks!!
              15mm all around.
              • KVF
                • 297
                #5452
                Thanks!!
                • madsedan
                  • 222
                  #5453
                  17x7.5 with offset of 35 work on my 91 coupe or is the offset no good?
                  Got a deal on some wheels from a Honda club guy but the offset is my concern.
                  Thanks!
                  '91 318is, S50 swap, Bilsteing/H&R race, Recaro SRD, etc.
                  • Mystikal
                    • 9602
                    #5454
                    Thanks!
                    They'll likely just clear the struts without spacers, but look very poor. 15mm spacers all around (or 20mm rear for even fitment).
                    • lambo
                      Captain Scene Points
                      • 10953
                      #5455
                      Quick question. I should be fine with 205/60 512's on my bcaps with gc coils, correct?
                      • frolf
                        • Nov 2005
                        • 191
                        #5456
                        Confirming question from a thread I just posted:
                        Will I be ok with 225/45-16 Falken 512s (tread width 7.7in) on my et23 Style 5 wheels seen in the '87 325i seen below?
                        Dan
                        • madsedan
                          • 222
                          #5457
                          Thanks Mystikal, awesome intel!
                          • Mystikal
                            • 9602
                            #5458
                            Yup.
                            • Mystikal
                              • 9602
                              #5459
                              Yes, if they're redrilled. If your car is 5-lug it will be very close to rubbing in the rear.
                              • frolf
                                • Nov 2005
                                • 191
                                #5460
                                Thanks! They are filled and drilled.
                                Dan
