This is a sticky topic.
  • lwde30
    • 73
    #6106
    ok im looking into getting bbs rs or ccw reps tire im going to be running is 195.50.15
    what offset would be good i want a flush look with a lil poke lol
    • lwde30
      • 73
      #6107
      also i dont mind running spacers
      • MC Hammered
        • Jul 2008
        • 2076
        #6108
        17x10 ET20 with 245/35/17 tire will it fit in the rear with just a rolled fender lip?
        Or do I need much more massaging?
        My 1989 e30 s52 Touring... this is Betty
        My 1989 325i vert (sold)...this is Nina
        My 1991 M5 (sold)... this is Veronica
        Photo comparison: OEM vs aftermarket windscreen for a convertible
        • jim325
          • 228
          #6109
          16x7.5 et23 I want to fit atleast a 225/45. Late model e30. Will I need to roll fronts? Will I need spacers up front to clear struts? Rears have flares so not to worried about rear. Prolly use falken fk 452's or nexen n3000's. Its a lowered daily driver.
          I have 16x8 et20 with 205/50 on now but looking to sell the wheels.
          Thanks. I tried looking thru the thread but i must have a.d.d.
          89 325i: 86 535i motor+trans, JE forged pistons, MLS head gasket, ARP head studs, Comp turbo, GoodNTight b34 turbo manifold, e30.de motor mounts, AKG 75D engine/trans mounts, custom 3" exhaust, intercooler, MS2PNP, Megan Racing Coilovers.
          • Mystikal
            Wheel Fitment Expert
            • 9602
            #6110
            Even with a super-stretched 225/35 17x10s require a bit of a pull to work properly. I'd put 245/35 in the realm of "doesn't fit" but enough fender work could change that.
            • Mystikal
              • 9602
              #6111
              Fits fine, no spacers. Note that those Nexens run extremely wide in that particular size (I test fit them once on my E30 on a 16x8 +20 wheel).
              • jellis
                • Dec 2012
                • 4
                #6112
                I am trying to decide what rims and what sizes to run on my '85 323i sedan.
                Option 1,
                17x10 +20 in the rear?
                17X9 +35 up front?
                http://www.enjukuracing.com/products...252d114.3.html
                Option 2,
                17x8.5 +20 allround
                BB5 R5
                I would like the rims to sit as close to flush with the guards as possible. I have a mate with a guard roller so rolling guards wouldnt be a problem id rather not pull them tho.
                The car will be on bc coilovers and it will be 70mm off the ground at its lowest point.
                cheers
                • Vivek
                  attention whore/retard/bitch
                  • 6167
                  #6113
                  How are e38 style 5's with 205/55 on a stock height e36? Any spacers/rings necessary?
                  Asking for a friend. Thanks.
                  1992 Mauritiusblau Vert
                  2011 Alpinweiss 335is coupe
                  2002 540i/6 Black/Black
                  2003 GSX-R 750 (RIP)
                  • Mystikal
                    • 9602
                    #6114
                    Option 1,
                    17X9 +35 up front?
                    Option 2,
                    17x8.5 +20 allround
                    BB5 R5
                    cheers
                    Option 1: 20mm front spacers to clear the struts. F: 205/40. R: 225/35.
                    Option 2: 205/40 all around. Probably toss a 5-10mm spacer on later to taste (even out front-rear stagger a bit on your early arches).
                    • Mystikal
                      • 9602
                      #6115
                      Gonna rub quite a bit unless his rear fenders are rolled. No spacers or rings.
                      • smokemhontas
                        • Sep 2012
                        • 50
                        #6116
                        I have 17x 9s and the offset is et22. Does anyone know if these will fit? As far as the front and back? I'm pretty low but I was planning on stretches too
                        • Mystikal
                          • 9602
                          #6117
                          Yes, I know. :p You'll need 8-10mm spacers to use those on the front axle, while the rears need nothing.
                          • bmwdready347
                            • Jan 2011
                            • 586
                            #6118
                            found some wheels that r 16x8 and r et 25 wanted to no if i can run 225 45 16 or even 235 45 16 in rear ..and 215 45 16 in front what do u think or should i go 17 and if so what offset to get im trying to get the widest drag radial tires in back as possible ..as soon as u give me the ok i am going to by the wheels,they r the
                            16X8 VARRSTOEN V4 4X100 +25 SILVER..let me no thanks
                            • lwde30
                              • 73
                              #6119
                              17x9 wit 225/40/17 offset ???? [what would be ideal]
                              will it work
                              im lowered on eibach sprint no camber kits.
                              also what are the best low cost way to adjust camber on these carrs
                              • e30lyf
                                • May 2007
                                • 4516
                                #6120
                                Hi!
                                i am running IE3,drop hats and koni sports. 16x7.5 et20 with 205/45/16.
                                what spacer should i run to look better for DD? TIA :)
                                Cheers,
                                - Fercy -
                                Classic BMW Specialists
                                Santa Clarita, CA
                                www.BimmerHeads.com
