This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #5356
    Originally posted by Insomniac912
    So I have a set of staggered Borbet A's i was looking to get new tires on.. I live in NJ and our roads are pretty shit for the most part. What size tires would be recommended without too much stretch?
    A's were built from 15" to 18".
    • Mystikal
      • 9602
      #5357
      Originally posted by drumad
      Are there any other tires out there I can get?
      Nope. You need those sizes.
      • Mystikal
        • 9602
        #5358
        Originally posted by MC Hammered
        For a 17x10 wheel what range of offsets will work in the rear of the e30?
        I assume it is pretty narrow, so using the Brocks in the post above would it be ET20 +/- ??
        +20 is about dead-on. Very little space left to the trailing arms.
        • balooshinakus
          • 511
          #5359
          Originally posted by Mystikal
          Originally posted by balooshinakus
          Hello,
          I'm looking to put 235-40-17 tires (star specs, maybe rcomp in the future?) on my car.
          I have an early model with e36m3 front suspension and inline6 z3 hubs on stock trailing arms in the back. I'm running about -2degree rear camber right now and about -3 degrees up front.
          I'm looking at getting 17x8 rims, but I'm not sure what offset I need. How easy of a fit will this but? My rear fenders are currently rolled a little bit, but the front isn't. Will I need to do a bunch of rolling to run these tires?
          Thanks!
          Which Z3?
          The inline 6 z3 (non-m) hubs on stock e30 trailing arms. I believe this adds about ~23mm to each side of the car but I'm not 100% sure on that number. Front suspension is e36m3 (coilovers).
          I'm wondering if I can get away with et38 17x8 rims (back is rolled) or if it will stick out too far. What would the ideal rim offset be?
          Thanks!
          • e30leigh
            • Mar 2012
            • 481
            #5360
            im gona give the 225s a go. if i need to pull then so be it. it will help it look bad ass as well haha
            • Insomniac912
              • Sep 2011
              • 288
              #5361
              Sorry, 16's x7.5 and 9
              • Mystikal
                • 9602
                #5362
                Thanks!
                Yes, the non-M 6cyl Z3s had the long axles. 17x8 +38 should be perfect for your setup.
                • Mystikal
                  • 9602
                  #5363
                  Offsets?
                  • jimmy mac
                    • May 2012
                    • 1
                    #5364
                    hi, im looking to run 17 rims 10" rears et15 and 8.5 fronts et 20..... on 1989 e30 325i the car will be slammed on bc racing coilovers with the arches well rolled, also streched tyre all round........ i know it will be tight but any advise on this set up would be great. thanks
                    • GunMetalGrey
                      • Dec 2010
                      • 1499
                      #5365
                      16x9
                      +25
                      Square setup, full size tires. Coilovers. I wouldn't mind running the dtm flares. Spacers are fine.
                      What is the best size tire I could stuff under it?
                      • drumad
                        • Aug 2009
                        • 1700
                        #5366
                        ^you're going to need at least 13mm spacers up front in order to clear the strut tube
                        2008 335i - n54b30
                        1991 318i - m52b28
                        1994 fzj80 - LAND CRUSHER
                        • Insomniac912
                          • Sep 2011
                          • 288
                          #5367
                          Offsets?
                          I've heard i need 195/50 front and 225/45 rear tires... correct?
                          • MaksV
                            • 1042
                            #5368
                            I am looking at a set of wheels that are 17x7.5 et 20
                            however I believe they are for a nissan cause the center bore is 59mm.
                            Wheels are ATS Comp Lites.
                            Questions:
                            1. Can I get away with not running any sort of hubcentric spacer. The car has studs if that makes a difference.
                            2. Does anyone make a 59 to 57mm adapter?
                            3. My car is on Konis and GC coils. 550f/750r. I plan on using my current 16s for track wheels. What tire size for the 17s would be good for the street. I would prefer to run a 225/45 but I am not sure how that would fit. Tires are probably federal s595s as I have good experiance with them.
                            Thoughts?
                            CHEAP REBUILT INJECTORS
                            Need Quality Brakes? BimmerBrakes has it!
                            For anything Else go with BluntTech!
                            • mbonanni
                              • Sep 2011
                              • 6236
                              #5369
                              15x7 et -3
                              15x10 et -28
                              Thoughts, advice, fitment?
                              • Mystikal
                                • 9602
                                #5370
                                205/40 and 225/35
